Full Version: Node Wish List
Show messages:  1-2  3-22  23-42  43-62  63-82  83-102  103-122  123-142  …  423-425
13 Dec 2019   [#63] In reply to [#61]
HI AlexPolo,
Just mouse click inside the picture frame to load an image. Set the resolution of the image before loading the image. It is the first released version. Improvements will made from user feed back.
I will check out the referances.
Wayne
13 Dec 2019   [#64] In reply to [#62]
Hi Finema,
Set the resolution of the knob, then reload the image. I will be making improvements on the interface.
Thank you,
Wayne
13 Dec 2019   [#65] In reply to [#64]
thanks Wayne, it's perfect !
good job !
13 Dec 2019   [#66]
Hi all,
I have red squares for reRange and PointExt :-( so I can't test it, unfortunately.
Where do I find those two and where do I have to install those?
I had this problem in the past too, with another node.
Is there an up to date alphabetic list of all required things for node editor,
where one can find all in one place, i.e. like a complete GitHub repository?
13 Dec 2019   [#67] In reply to [#66]
Normally last version of Node Editor is here managed by James
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
13 Dec 2019   [#68]
Thank you Pilou, that did the trick! :-)
13 Dec 2019   [#69]
Hi Wayne,
I have red square highlight on image sampler node and cant load image file. I have updated node editor to current version and placed node in correct location in USER/APPDATA/ROAMING location.
Something else missing?
13 Dec 2019   [#70] In reply to [#69]
Alex
Sorry, I had not yet updated CURRENT NODEEDITOR FOLDER to include ImgSampler.
Please reload with updated zip file attached to this post:
Have a great weekend
13 Dec 2019   [#71] In reply to [#70]
James,
Can you holdup on including the new node into the zip file. There are some graphic updates that are being worked on.
Thank you,
Wayne
13 Dec 2019   [#72] In reply to [#70]
Thanks all working now.
looking good.
Message 9581.73 was deleted
Message 9581.74 was deleted
13 Dec 2019   [#75]
Updated ImgSample.js node at:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57
Wayne
13 Dec 2019   [#76] In reply to [#75]
CURRENT NODEEDITOR FOLDER updated with most recent version of ImgSampler:
14 Dec 2019   [#77] In reply to [#76]
Cool and endless add to the my repository (no yet made...maybe this evening) :)
15 Dec 2019   [#78]
Hi Wayne and all,
thanks so much for your node, it is really cool!
Here is a small project I am currently working on:
The Go Gopher* Mascot from Google's programming language Go.
And the Image was taking from the Google folder on GitHub and
then redrawn with MoI, brought into the free ArtForm 4 to create
a relief and depth map from it. The depth map then was taken into
your node. Finally trimmed and scaled in MoI.
*Creator of the Go Gopher is Artist Renée French.
This is currently my progress:
gopher-NURBS
16 Dec 2019   [#79]
And final model, hope you like.
Go-Gopher-final8
16 Dec 2019   [#80]
Flatty personnage! :)
16 Dec 2019   [#81]
He he, :-)
And here is a final rendering:
Go-Gopher
16 Dec 2019   [#82] In reply to [#81]
Looks great Stefan! That is a charming character for sure.
