Full Version: Node Wish List
Show messages:  1-3  …  364-383  384-403  404-423  424-425
28 Mar 2024   [#424] In reply to [#423]
Hi Barry
One way is to use the "Split" node to split the points with a 0-1 mask. (.nod file attached)
You can achieve the same result with the "Pattern select" node.
Split_PointArray.nod
28 Mar 2024   [#425] In reply to [#424]
Thanks Mo,
Have got a result by using 2 point array nodes but not that elegant.
Will try your method.
Many thanks
Barry
