Full Version: Node Wish List
Show messages:  1-2  …  363-382  383-402  403-422  423-425
28 Mar 2024   [#423]
I have a pointarray of 3x by 6y as an example.
I want to select every other line in the Y. and move them in the X.
ie: lines 2/4/6
Any ideas welcome.
Barry
28 Mar 2024   [#424] In reply to [#423]
Hi Barry
One way is to use the "Split" node to split the points with a 0-1 mask. (.nod file attached)
You can achieve the same result with the "Pattern select" node.
Split_PointArray.nod
28 Mar 2024   [#425] In reply to [#424]
Thanks Mo,
Have got a result by using 2 point array nodes but not that elegant.
Will try your method.
Many thanks
Barry
