 360-379
 380-399
 400-419
 420-425
Just a question.
I have been playing with r2d3 text node it as a input for text
but I can’t find away of using the input other than with numbers
 or directly inputting text within the node.
Could a node that carries text be created that could be plugged into the
Text node ?
Cheers Barry
Hi Barry
Currently, Nodeeditor doesn't support the "string" type.
I'm working on adding some extra features into it, including strings. :)
Hi Mo,
Looks good.
Barry
I have a pointarray  of 3x  by  6y as an example.
I want to select every other line in the Y. and move them in the X.
ie: lines 2/4/6
Any ideas welcome.
Barry
Hi Barry
One way is to use the "Split" node to split the points with a 0-1 mask. (.nod file attached)
You can achieve the same result with the "Pattern select" node.
Split_PointArray.nod
Thanks Mo,
Have got a result by using 2 point array nodes but not that elegant.
Will try your method.
Many thanks
Barry
 360-379
 380-399
 400-419
 420-425
