Full Version: Node Wish List
Show messages:  1-15  …  356-375  376-395  396-415  416-425
10 Mar 2024   [#416] In reply to [#414]
>I'm not seeing where ArrayGem.js for the node editor is posted, can you post a link to the message where Chrome is not allowing you to download from?
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1858
Edit: how can I fix the issue of "invalid character #" error?
-Psygorn
10 Mar 2024   [#417] In reply to [#415]
I got confused and need help here:
ArrayGem_node.js is a different file from ArrayGem.js.
and MOI shows an error message I showed in my previous reply.
- Psygorn
10 Mar 2024   [#418] In reply to [#417]
HI Psygorn, the one that Brian posted above is the one you need, the attachment ArrayGem_node.txt here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.415
So delete your ArrayGem.js that is giving the "invalid character #" message, download ArrayGem_node.txt from Brian's post above and rename it ArrayGem.js and put it into the node editor extensions folder.
10 Mar 2024   [#419] In reply to [#418]
Thank you Michael.
-Psygorn
17 Mar 2024   [#420]
Just a question.
I have been playing with r2d3 text node it as a input for text
but I can’t find away of using the input other than with numbers
or directly inputting text within the node.
Could a node that carries text be created that could be plugged into the
Text node ?
Cheers Barry
18 Mar 2024   [#421] In reply to [#420]
Hi Barry
Currently, Nodeeditor doesn't support the "string" type.
I'm working on adding some extra features into it, including strings. :)
19 Mar 2024   [#422] In reply to [#421]
Hi Mo,
Looks good.
Barry
28 Mar 2024   [#423]
I have a pointarray of 3x by 6y as an example.
I want to select every other line in the Y. and move them in the X.
ie: lines 2/4/6
Any ideas welcome.
Barry
28 Mar 2024   [#424] In reply to [#423]
Hi Barry
One way is to use the "Split" node to split the points with a 0-1 mask. (.nod file attached)
You can achieve the same result with the "Pattern select" node.
Split_PointArray.nod
28 Mar 2024   [#425] In reply to [#424]
Thanks Mo,
Have got a result by using 2 point array nodes but not that elegant.
Will try your method.
Many thanks
Barry
