Full Version: Node Wish List
Show messages:  1-5  …  346-365  366-385  386-405  406-425
2 Feb 2024   [#406] In reply to [#405]
Hi Mo,
no error message and have just tried again no problem at all.
Must have been my error.
Will update my Sections nod file as an example.https://moi3d.com/forum/index.php?webtag=MOI&msg=11314.71
Barry
2 Feb 2024   [#407] In reply to [#406]
Thanks. :)
2 Feb 2024   [#408] In reply to [#406]
After seeing your nod file, I came up with an idea to switch the text with an index number.
For "switch text by index" to work, you need to change the newly added "mode" property to "Index" and separate your text by three stars (***).
See the attached nod file.
Note.js
Note_Index_Mode.nod
2 Feb 2024   [#409] In reply to [#408]
Hi Mo,
excellent node.
Is it possible to have a index position that shows the choices because they are not visible one run is pressed.
Many thanks
Barry
2 Feb 2024   [#410] In reply to [#409]
Hi Barry
Sorry, It needs nodeeditor to be running to work properly.
Although, I added the page system to display the number of choices.
Updated my earlier post.
9 Mar 2024   [#411] In reply to [#387]
Hi all,
I am using Google Chrome and when I want to download "ChamferCurve.js" it says "Virus Detected" and stops downloading process.
Do you know how I can fix this? or could you send it to me (like changing it's format from .js to .txt)
Edit: it also happens for "ArrayGem.js" so, if you could send that to me; I would appreciate it :-)
- Psygorn
9 Mar 2024   [#412] In reply to [#411]
ArrayGem.txt
ChamferCurve.txt
9 Mar 2024   [#413] In reply to [#412]
Thank you Zooen,
But now I see this!
How can I fix this?
-Psygorn
9 Mar 2024   [#414] In reply to [#413]
Hi Psygorn, re: "invalid character #" error, it looks like there are probably 2 different files named ArrayGem.js, one is the built in command in the commands folder and the other is I guess a node editor extension.
It looks like you've got the command one there instead of the node editor extension file like you want.
I'm not seeing where ArrayGem.js for the node editor is posted, can you post a link to the message where Chrome is not allowing you to download from?
9 Mar 2024   [#415] In reply to [#413]
ArrayGem node:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1858
Rename .txt to ArrayGem.js.
Add to the extensions folder of nodeeditor. (AppData>etc.)
This node will be in the Objects2 node menu.
ArrayGem_node.txt
10 Mar 2024   [#416] In reply to [#414]
Edit: how can I fix the issue of "invalid character #" error?
-Psygorn
10 Mar 2024   [#417] In reply to [#415]
I got confused and need help here:
ArrayGem_node.js is a different file from ArrayGem.js.
and MOI shows an error message I showed in my previous reply.
- Psygorn
10 Mar 2024   [#418] In reply to [#417]
HI Psygorn, the one that Brian posted above is the one you need, the attachment ArrayGem_node.txt here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.415
So delete your ArrayGem.js that is giving the "invalid character #" message, download ArrayGem_node.txt from Brian's post above and rename it ArrayGem.js and put it into the node editor extensions folder.
10 Mar 2024   [#419] In reply to [#418]
Thank you Michael.
-Psygorn
17 Mar 2024   [#420]
Just a question.
I have been playing with r2d3 text node it as a input for text
but I can’t find away of using the input other than with numbers
or directly inputting text within the node.
Could a node that carries text be created that could be plugged into the
Text node ?
Cheers Barry
18 Mar 2024   [#421] In reply to [#420]
Hi Barry
Currently, Nodeeditor doesn't support the "string" type.
I'm working on adding some extra features into it, including strings. :)
19 Mar 2024   [#422] In reply to [#421]
Hi Mo,
Looks good.
Barry
28 Mar 2024   [#423]
I have a pointarray of 3x by 6y as an example.
I want to select every other line in the Y. and move them in the X.
ie: lines 2/4/6
Any ideas welcome.
Barry
28 Mar 2024   [#424] In reply to [#423]
Hi Barry
One way is to use the "Split" node to split the points with a 0-1 mask. (.nod file attached)
You can achieve the same result with the "Pattern select" node.
Split_PointArray.nod
28 Mar 2024   [#425] In reply to [#424]
Thanks Mo,
Have got a result by using 2 point array nodes but not that elegant.
Will try your method.
Many thanks
Barry
