 344-363
 364-383
 384-403
 404-423
 424-425
Thanks Mo I have used a number system now and it works ok.
Barry
Cool, I'll be happy to see the way you do it in an example nod.
>> is there a limit to the number of Note nodes you can have ?
I don't have this issue here, do you get an error when this happen?
Hi Mo,
no error message and have just tried again no problem at all.
Must have been my error.
Will update my Sections nod file as an example.https://moi3d.com/forum/index.php?webtag=MOI&msg=11314.71
Barry
Thanks. :)
After seeing your nod file, I came up with an idea to switch the text with an index number.
For "switch text by index" to work, you need to change the newly added "mode" property to "Index" and separate your text by three stars (***).
See the attached nod file.
Note.js
Note_Index_Mode.nod
Hi Mo,
excellent node.
Is it possible to have a index position that shows the choices because they are not visible one run is pressed.
Many thanks
Barry
Hi Barry
Sorry, It needs nodeeditor to be running to work properly.
Although, I added the page system to display the number of choices.
Updated my earlier post.
Hi all,
I am using Google Chrome and when I want to download "ChamferCurve.js" it says "Virus Detected" and stops downloading process.
Do you know how I can fix this? or could you send it to me (like changing it's format from .js to .txt)
Edit: it also happens for "ArrayGem.js" so, if you could send that to me; I would appreciate it :-)
- Psygorn
ArrayGem.txt
ChamferCurve.txt
Thank you Zooen,
But now I see this!
How can I fix this?
-Psygorn
Hi Psygorn, re: "invalid character #" error, it looks like there are probably 2 different files named ArrayGem.js, one is the built in command in the commands folder and the other is I guess a node editor extension.
It looks like you've got the command one there instead of the node editor extension file like you want.
I'm not seeing where ArrayGem.js for the node editor is posted, can you post a link to the message where Chrome is not allowing you to download from?
ArrayGem node:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1858
Rename .txt to ArrayGem.js.
Add to the extensions folder of nodeeditor.  (AppData>etc.)
This node will be in the Objects2 node menu.
ArrayGem_node.txt
Edit: how can I fix the issue of  "invalid character #" error?
-Psygorn
I got confused and need help here:
ArrayGem_node.js is a different file from ArrayGem.js.
and MOI shows an error message I showed in my previous reply.
- Psygorn
HI Psygorn, the one that Brian posted above is the one you need, the attachment ArrayGem_node.txt here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.415
So delete your ArrayGem.js that is giving the "invalid character #" message, download ArrayGem_node.txt from Brian's post above and rename it ArrayGem.js and put it into the node editor extensions folder.
Thank you Michael.
-Psygorn
Just a question.
I have been playing with r2d3 text node it as a input for text
but I can’t find away of using the input other than with numbers
 or directly inputting text within the node.
Could a node that carries text be created that could be plugged into the
Text node ?
Cheers Barry
Hi Barry
Currently, Nodeeditor doesn't support the "string" type.
I'm working on adding some extra features into it, including strings. :)
Hi Mo,
Looks good.
Barry
I have a pointarray  of 3x  by  6y as an example.
I want to select every other line in the Y. and move them in the X.
ie: lines 2/4/6
Any ideas welcome.
Barry
 344-363
 364-383
 384-403
 404-423
 424-425
