Full Version: Node Wish List
Show messages:  1-17  …  318-337  338-357  358-377  378-397  398-417  418-425
22 Jan 2024   [#378] In reply to [#377]
Hi Mo,
can you make a node of your script please
I have very limited coding and will probably take forever.
Barry
22 Jan 2024   [#379]
Link on (various) Fillet node(s), and Chamfer node(s), from 2 and 4 years ago, with good information from Michael:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9666.1
(various Fillet and Chamfer nodes, are located in nodeeditor menus Curves2 and Construct2 menus. Some of them are probably not mature, fully functional nodes, and may need improvements from someone who knows what they are doing. And has understanding (?)) (Like grafting in MO-TE's code ?)
22 Jan 2024   [#380] In reply to [#379]
I've just removed them from my nodeditor as Mo added new versions of fillet and chamfer edges into the construct menu.
I think a new thread maybe worth starting to filter out some of duplicate nodes and add new developed nodes that people want to share.
Anyway many thanks for your input.
Barry
22 Jan 2024   [#381] In reply to [#380]
Thankyou Barry.
It seems that my nodeeditor, for this pc especially, is not up to date, with some "obsolete"/ defective nodes.
22 Jan 2024   [#382] In reply to [#378]
Hi Barry
I was working on a new version of fillet node months ago, with ability to pick corner points directly from the scene, I guess I can add my new findings to it.
It's still buggy and I'm not sure when it'll be ready.
I'm not that skilled too. :)
22 Jan 2024   [#383] In reply to [#382]
Hi MO_TE
Thank you for your hard work. You seem very skilled with the Javascript & Nodes.
I like the way that you break up Max's paragraphs of code into individual code lines. This tends to make them more comprehensible IMHO.
Is this "parsing" done by some editing software?
Notepad++ does not break down these code "paragraphs".
22 Jan 2024   [#384] In reply to [#382]
Thanks Mo,
much appreciated.
Would be good to add fillet and chamfer to the curves section if possible.
Barry
22 Jan 2024   [#385] In reply to [#383]
Hi Brian
Thanks, I wish I was. ;)
I use notepad++ with language set to JavaScript.
Maybe this helps you to format/beautify your codes:
https://beautifier.io/
24 Jan 2024   [#386] In reply to [#385]
Thank you MO_TE for the JS-beautify link.
27 Jan 2024   [#387]
"FilletCurve" and "ChamferCurve" nodes
Fillet/chamfer multiple curves at once.
You can choose a specific corner point to fillet or chamfer or set a pattern of 01 to fillet/chamfer curves.
How to use it?
Start nodeeditor and connect your curves to the node.
Click on the "FilletCurve" node to open the information panel.
In the "Select" dropdown menu choose the "sharp points" option.
This way you can see and choose the corner points in the scene.
When you finished picking corner points, choose the "Done" option from "Select" dropdown menu.
Also see the attached "FilletCurve_Showcase.nod" for an example.
Address:
Construct/FilletCurve
Construct/ChamferCurve
ChamferCurve.js
FilletCurve.js
27 Jan 2024   [#388] In reply to [#387]
Hi Mo,
Excellent will give them a try.
Many thanks
Barry
27 Jan 2024   [#389]
Excellent!
27 Jan 2024   [#390] In reply to [#387]
Hi Mo,
quick update.
When filleting a selected object and applying the original object remains and cannot be deselected as normal (mouse click).
Perhaps keeping original is not needed.
Barry
27 Jan 2024   [#391] In reply to [#390]
Hi Barry
Thanks for the bug report.
I've fixed the lock selection bug. Try updated version.
27 Jan 2024   [#392] In reply to [#391]
Hi Mo,
works fine many thanks.
Barry
27 Jan 2024   [#393] In reply to [#387]
In fact we must make our own schema from your example ?
(killing some nodes and save it ) that works fine...
Or there is an original somewhere ?
Or I miss something ?
(here in French for some nodes because i have French enable! :)
27 Jan 2024   [#394] In reply to [#393]
Hi PILOU
I modified my main.js to have more colors. But, there should be no difference in terms of working.
Actually, I was working on implementing some new features of this "litegragh" fork into the old nodeeditor. But, I haven't released it yet.
https://github.com/atlasan/litegraph.js
It works nice, But, I have some problems with html and css parts.
I was hoping to find someone interested/skilled to help me finish it! :)
27 Jan 2024   [#395] In reply to [#394]
THx for the infos! And alas i can't help you on these difficult domains! :( (for me)
27 Jan 2024   [#396] In reply to [#387]
MO,
RE: "FilletCurve" and "ChamferCurve" nodes
This is some impressive work. Indeed the facility for selecting vertices is such a profound contribution, that I really feel it is deserving of its own node.
As well as isolating vertices for fillet/chamfer operations, it could, for example add a trim point on a curve; and in the instance where there were coincidental end point, perform selective joining of curves; etc etc.
Also vertices could be output as points for the locating of other objects/geometry/vectors; or be the targets for operations (eg extrude to point).
Generally I am resistant to the tendency towards node library bloat, but in this case I believe that it would beneficial to take this facility for vertex selection out of your new nodes and universalise it into a dedicated node.
Either way; Brilliant work.
Keep it up.
PS Another thought: Could node have an "index" number array output as an alternative option?
28 Jan 2024   [#397] In reply to [#396]
Hi James
Thanks for your ideas. I hadn't thought about using the corner points like this.
Although, I should think more about adding a break to curve or merging curve segments.
I was thinking about adding a new node for selecting sub-objects like edges and faces to use them in filletEdges, blend, offset, inset, extrude, n-sided, network and shell nodes.
Maybe I can add an extra "point" option to it.
One thing I'm not sure about is if is it better to write a "select sub-objects" node and rewrite other nodes above to work with it,
Or, add selection function like "filletCurves" to all of them. (I guess the first one is faster and easier!)
