Full Version: Node Wish List
Show messages:  1-11  …  292-311  312-331  332-351  352-371  372-391  392-411  412-425
12 Dec 2023   [#352]
"Note" node
Note node to display notes, numbers and point data on canvas.
Use pointers to move between pages.
Hold down the Shift key and click on the arrows to move through the pages 10 times faster.
Right click options:
Switch between exact and round presentation of numbers. (Default: round numbers up to 3 float numbers)
Choose points order presentation. (point groups) (Default: x length)
Page navigation
Thanks for great suggestions James.
Multiline Text Justification Credit:
https://stackoverflow.com/questions/6517999/how-to-justify-align-text-in-html5-canvas
Address: Infos/Note
Note.js
12 Dec 2023   [#353]
Very cool effort!
16 Dec 2023   [#354] In reply to [#352]
MO,
Thank you for Note node. The ability to annotate node circuits will greatly aid in clarifying complex wirings, particularly when returning to them after extended absence.
Also, not only does this node replaces r2d3/display node, but similarly displays point data. One feature that may not be immediately apparent, but will nevertheless be exceedingly useful is the display of ordered pts by x-length, y-length, or z-length.
Thank you, your efforts are to be applauded
11 Jan 2024   [#355]
can anybody make a switch node that as one input and two outputs basically the existing switch in reverse.
Barry
11 Jan 2024   [#356] In reply to [#355]
I will have a look, to see if the inputs and outputs can be coded "in reverse".
Using an electrical analogy is complicated by the fact that the Nodes have Inputs and Outputs, which introduces a "direction" to the data flow.
Electricity could flow in either direction.
The new requested switch is properly called a SPDT, (Single Pole, Double Throw) switch, with one input Pole, and two output terminals.
The existing switch is a "Backward flow" version of this, with two poles and double throw, but the term DPST is not appropriate.
>>>And the code for this node is in the Interfaces.js file.<<<
The SwDPDT switch node which I did is actually a "Backward flow" switch.(?)
So there could be two versions of the SwDPDT switch node.
And two versions of the SwRotary switch node.
https://www.quora.com/What-type-of-electric-switch-do-I-have-to-use-for-two-inputs-and-one-output
https://www.turito.com/blog/physics/types-of-switches
https://www.amplifiedparts.com/tech-articles/switch-poles-and-throws
https://www.edrawsoft.com/basic-electrical-symbols.html
11 Jan 2024   [#357] In reply to [#355]
Hi Barry,
Attached is a draft node, SwSPDT_DRAFT.js.
It has one input, and two outputs.
It may be copied to the nodeeditor Extensions folder, and when MoI & Nodeeditor are re-opened, the node will appear in the Widgets menu.
The Bezier curved connection indicator was modified by trial and error, based upon some Bezier information.
Control point 1 and cp2 "x" values were swapped, and some Y and 10 values were interchanged.
Due to limited Bezier understanding, the changes seem a bit "mysterious".
There is a link in the SwDPDT.js file to some Bezier/canvas information.
...Got some help from Wayne a few years ago...
The non-switch selected Terminal is "floating"?
The main problem is that the Output switched away from should perhaps be reset with some default value?
What should the default value be? It must be numeric?
Display has a "NoInput" default value, but does not reset to NoInput.
Is there some numeric "null" value?
The SwSPDT_Draft node may have a Const node input.
Each Output can be wired to an Infos > Display node.
Testing was rudimentary...
Someone who knows what they are doing should check it out...
Anyway, had some fun.
Cloned 256mb PCIe 4.0 NVMe M.2 SSD with Samsung software, to new Samsung 990PRO, 2TB, which replaced the old boot SSD on Dell computer. It was easy using a portable NVMe case to USB adapter, (temporary for the cloning). (Windows 11)
This SwSPDT_Draft node contains several errors.
The errors are corrected in WN's switchRevers.js file (RevSwitch)
swSPDT_DRAFT.js
12 Jan 2024   [#358] In reply to [#357]
Thanks Brian
will give it a go and let you know how I get on.
Barry
Ps
getting this error when changing switch to objects
TypeError: undefined is not an object (evaluating 'this.inputs[slot].type = type')
moi://appdata/nodeeditor/core/main.js line 1871
1867: */
1868: LGraphNode.prototype.changeInputType = function(slot, type, name)
1869: {
1870: this.disconnectInput(slot);
1871: >> this.inputs[slot].type = type;
1872: this.inputs[slot].name = name || this.inputs[slot].name;
1873: this.size = this.computeSize();
1874: if (!this.graph) return;
1875: this.graph.refreshNodeInfo(this.id);
12 Jan 2024   [#359]
Based on Max's node.
RevSwitch.nod
switchRevers.js
12 Jan 2024   [#360] In reply to [#358]
I "dis-remembered" that there are 3 types :-(, :-).
Recall seeing type code for 3 types.
If the switch were for electronics, there might be a "pull up" resister on each output terminal?
The code that I did was all modifications of Max's code.
Will look at switchReverse later today.
12 Jan 2024   [#361] In reply to [#359]
Hi WN,
thanks for the node but having issues when directing input from one circuit to another.
Attached a nod file showing the issue.
One circuit adds a fillets to the input square & the second does not.
Using the numbers option seems Ok.
Barry
RevSwitch.nod
12 Jan 2024   [#362] In reply to [#361]
Hi Barry.
In fact, there is no need for this node, since there are the necessary nodes for this.
I assume that you are aware of this. The node that I uploaded here is a small fix for
the 'Switch' node with a small addition from the 'Split' node that is in the 'logic' file.
I fixed the error and updated the file in the same message.
WN.
12 Jan 2024   [#363] In reply to [#362]
Hi WN,
thank you for the node works fine.
Yes split node does the same (not used it before).
Many thanks
Barry
12 Jan 2024   [#364] In reply to [#362]
Hi WN,
It was a pleasure to review your RevSwitch file, to see the numerous corrections to the SwSPDT.js file that I did in an attempt to modify Max's Switch node.
Number of inputs and outputs, for each of the 3 datatypes was done.
(Code from Logic > Split node, I see.)
I broke the bezier color somehow.
I see that you modified the bezier, somehow, using the "same" code.
You introduced the dataNull.
Even though the RevSwitch function is already covered in the Logic > Split node, the Bezier indicator curve is nice to see.
21 Jan 2024   [#365]
not sure if there is a answer for this
Shown is a photo showing a square that as one corner already filleted.
When object is selected and crvfilllet node used to fillet the remaining corners
it produces the result on the right or fails.
Any ideas ?
Barry
21 Jan 2024   [#366] In reply to [#365]
It looks like the node is trying to fillet points 4 and 5.
Is there a way to exclude the end points of the pre-existing fillet, from the new fillet?
Can the initial object be posted?
Would a join help?
Is there some way to identify all of the characteristics of the points?
21 Jan 2024   [#367] In reply to [#366]
the node needs away of knowing if the point is G0.
If the curve is rebuilt it works fine but you end up with a lot more control points.
Barry
21 Jan 2024   [#368] In reply to [#367]
Moi4 introduced a bunch of methods, tangents and derivatives...etc
21 Jan 2024   [#369] In reply to [#368]
Here's a function for checking if a pair of curves is G1.
- Peer
// returns true if curve1 is tangent to curve2
function getCurvePairIsG1(curve1, curve2) {
    var curve1startPt = curve1.getStartPt();
    var curve1endPt = curve1.getEndPt();
    var curve1startTan = curve1.evaluateTangent(curve1.domainMin);
    var curve1endTan = curve1.evaluateTangent(curve1.domainMax);
    var curve2startPt = curve2.getStartPt();
    var curve2endPt = curve2.getEndPt();
    var curve2startTan = curve2.evaluateTangent(curve2.domainMin);
    var curve2endTan = curve2.evaluateTangent(curve2.domainMax);
    // flip one of the tangent vectors in the pair being compared for end-end and start-start cases
    var curve1startTanNeg = moi.vectorMath.createPoint(curve1startTan.x, curve1startTan.y, curve1startTan.z);
    curve1startTanNeg.scale(-1.0);
    var curve1endTanNeg = moi.vectorMath.createPoint(curve1endTan.x, curve1endTan.y, curve1endTan.z);
    curve1endTanNeg.scale(-1.0);
    var tol = moi.geometryDatabase.tolerance;
    // curve1 start curve2 end
    if (
        moi.vectorMath.distance(curve1startPt, curve2endPt) < tol &&
        moi.vectorMath.distance(curve1startTan, curve2endTan) < tol
        return true;
    // curve1 end curve2 start
    else if (
        moi.vectorMath.distance(curve1endPt, curve2startPt) < tol &&
        moi.vectorMath.distance(curve1endTan, curve2startTan) < tol
        return true;
    // curve1 start curve2 start
    else if (
        moi.vectorMath.distance(curve1startPt, curve2startPt) < tol &&
        moi.vectorMath.distance(curve1startTanNeg, curve2startTan) < tol
        return true;
    // curve2 end curve2 end
    else if (
        moi.vectorMath.distance(curve1endPt, curve2endPt) < tol &&
        moi.vectorMath.distance(curve1endTanNeg, curve2endTan) < tol
        return true;
    else {
        return false;
21 Jan 2024   [#370] In reply to [#368]
Or for a planar joined curve you can use a G1 checker that's built into fillet factories. Search "GetCorners" in the API for an example of how to do that.
- Peer
21 Jan 2024   [#371]
I tried to fillet a selected curve with code below.
It makes a list of "true" values for all corner points of the curve to fillet all of them.
Let's say I have a polyline consists of two segments and one corner point.
Logically, the corners List should be like this : {true}
This approach works on closed curves like a rectangle, but, fails on open curves. I need to add an extra "true" value to the list for open curves to work.
Also it fails on open and closed curves with an existing fillet or non "G0" continuity.
Like the one Barry showed in (9581.365)
Am I missing something?
script:
var inputs = moi.geometryDatabase.getSelectedObjects().getStandaloneCurves();
var filletFacc = moi.command.createFactory('fillet');
var filletFacToGetCorners = moi.command.createFactory('fillet');
filletFacToGetCorners.setInput(0, inputs);
filletFacToGetCorners.generateVertices();
var corners = filletFacToGetCorners.getCreatedObjects();
filletFacToGetCorners.cancel();
var cornersList = moi.createList();
if(inputs.item(0).isClosed)
for ( var i = 0; i < corners.length; ++i ) {cornersList.add( true );};
}else
for ( var i = -1; i < corners.length; ++i ) {cornersList.add( true );};
filletFacc.setInput(0, inputs);
filletFacc.setInput(1, false);
filletFacc.setInput(2, cornersList);
filletFacc.setInput(3, 1);
filletFacc.setInput(4, 'Circular');
filletFacc.setInput(5, 1);
filletFacc.commit();
moi.log("inputs: "+inputs.length+"\n");
moi.log("Corners: "+corners.length+"\n");
moi.log("cornersList: \n");
for ( var i = 0; i < cornersList.length; ++i ) {moi.log(cornersList.item(i)+"\t")};
moi.log("\n");
