Full Version: Node Wish List
Show messages:  1-19  …  220-239  240-259  260-279  280-299  300-319  320-339  340-359  …  420-425
24 Mar 2022   [#280] In reply to [#276]
Brian,
quote:
Free Book:
http://algorithmicbotany.org/papers/abop/abop.pdf
Thank you for the link. I download & voraciously devoured its content.
Moreover I have returned it again & again...Lindenmayer's insight was extraordinary:
that a simple set of instructions applied recursively would generate limitless patterns and forms, but further that a subset of these would be facsimiles of forms found in nature. Though for me at least, it is the novel pattern generation that is most exciting, particularly those that possess aperiodicity like the explorations of Roger Penrose.
Much to think about,
Thanks again,
24 Mar 2022   [#281] In reply to [#280]
Thank you James, and for the example of the Gate node.
25 Mar 2022   [#282]
Cool pdf!
In the same order of idea
http://www.entrelacs.net/-Celtic-Knotwork-The-ultimate- by hand
With computer ;)
http://www.hypatiasoft.fr/Folder_KnotsBag/Pages_HTML/KnotsBag_A.html
and my little prog online! ;)
Drag & Drop any png image with a transparent background...(better 1024* 512 )
(An JPG image will made a neutral result )
https://editor.p5js.org/Pilou/full/y1GHaBqyT
you will obtain some funny images
here for example with an Moi obj
or with my recent Gaugan pilouterie :)
25 Mar 2022   [#283]
Hi All,
This is what I have so far on my alpha version of L-System for the Node Editor. Still working on the interface. All the l-system samples are working so far.
Wayne
25 Mar 2022   [#284] In reply to [#283]
Wayne,
It is looking great...very exciting.
I see that you are closely following the approach of onlinemathtools.com/l-system-generator, including its input values of width & height. I purposely excluded these from my node proposal because the consequent distortion of the output would generally be undesirable. The spatial limitation of displaying within the webpage necessitates the inclusion of these (w,h) input values. The virtual 3d space has no such limitation, besides any requirement for scaling and proportioning may be achieved subsequently with Objects2/ScaleUVW node.
I understand that you are at beta stage and the interface considerations are far from fixed (and you have likely had the same thought) , but the inclusion on the node of inputs for angle and iterations would give greater dynamic control of output.
I also know that there is no scaling factor per generation included in the js code of the online tool, but if this facility was possible it would push the capabilities into a realm beyond; opening up a new world of possibility....worthy of consideration!
Again, thank you for your hard work with this. I can't wait to get my hands on it.
Keep up the good work,
25 Mar 2022   [#285] In reply to [#281]
Brian,
quote:
Thank you .....for the example of the Gate node.
The Gate node is one of my meagre contributions to node library from a few years back.
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=7777.1251
At the time I thought these would be a real boon to NE's capabilities; after-all digital computation
is based on logic gates.
Instead it languished; all but ignored (even by me).
When we lost John Conway to covid, I attempted to build a cellular automaton circuit
for his "Game of Life" in NE, however never managed to get it to work.
A project for another time....unless it piques your interest.
Have a great weekend,
26 Mar 2022   [#286] In reply to [#285]
Is "Game of Life" an L-System?
26 Mar 2022   [#287] In reply to [#286]
Brian,
quote:
Is "Game of Life" an L-System? - Brian
No, if you reread my post, it was in response to your post about the logic gate node, not L-Systems.
Cellular Automaton replies on conditional logic to test each cell's adjacent neighbours at each iteration to operate,
so it should be possible to build in NE with the use of logic nodes.
See the wikipedia entry for generative rules:
https://en.wikipedia.org/wiki/Conway%27s_Game_of_Life
26 Mar 2022   [#288]
You have an another cellular Automate with a very simple rule!
Turmites : If it's Black turn on the right!
if it's white turn on the left!
Amazing that after some repetition a striah line apaers from the chaos! :)
Maybe with Moi adtapt it in 3D...
And the top of the must free prog about all the 2D Cellular Automates Golly
http://golly.sourceforge.net
Here with the game of life rules!
28 Mar 2022   [#289]
Found this :)
https://personalpages.manchester.ac.uk/staff/j.montaldi/Choreographies/
1 Apr 2022   [#290]
Lsystem New Node!
https://en.wikipedia.org/wiki/L-system
The dropdown menu has several demo patterns.
Select 'Custom' menu to make your own custom pattern based on the previous selection.
Start with a low iteration number when making a custom demo. The calculations can easily overwhelm
the MOI graphic processor.
Thank you to James for the testing and recommendations.
Wayne
lsystem.js
1 Apr 2022   [#291] In reply to [#290]
The famous Penrose tilling! The double flying kite! :)
2 Apr 2022   [#292]
PS There is no .nod file for the Lsystem ? Only a js file ?
Edit : ok Found! :) Just put the JS file inside the folder (for PC) ...\Moi\nodeeditor\nodes\extensions\lsystem.js
Will be in the Node / Objects2 if i am right...
Insert 3 nodes "sliders" a an "OutPut" et voilĂ !
And so the .nod! ;) https://moiscript.weebly.com/uploads/3/9/3/8/3938813/lsystem_pil.nod
and the site ;) https://moiscript.weebly.com/objects2.html#lsystem
Absolutly terrific! Bravo! Another infinite toy!
2 Apr 2022   [#293]
quote:
Lsystem New Node!
eureka, i was asking for something like this 9 years ago
https://moi3d.com/forum/index.php?webtag=MOI&msg=6148.17
tnx
3 Apr 2022   [#294]
Marco / Pilou ,
Very happy you like it.
Wayne
3 Apr 2022   [#295] In reply to [#294]
Used for my hundred of the day! ;) https://imgbox.com/g/tSQCUyur6z
13 Mar 2023   [#296]
A modification to the Node Editor to allow multiple object connections.
It is as simple as commenting out one line on the 'main.js' program.
// >>>  if ( this.outputs[slot].type === "objectlist" ) this.disconnectOutput(slot);
LGraphNode.prototype.connect = function (slot, node, target_slot) {
//special case: -1 means node-connection, used for triggers
var output = this.outputs[slot];
if (target_slot === -1) {
	if (output.links == null) output.links = [];
	output.links.push({
		slot: -1
} else if (!output.type || //generic output
	!node.inputs[target_slot].type || //generic input
	output.type.toLowerCase() == node.inputs[target_slot].type.toLowerCase()) //same type
	{ // 4-12-2022 wjh
14 Mar 2023   [#297] In reply to [#296]
Hi
Thank you wayne. With this modification, we can say goodbye to the "clone" node ! :D
Sometimes an indestructible Object appears in the scene.
The problem will solve after saving the scene and restarting moi.
15 Mar 2023   [#298]
Thank you MO!
Here is another one you might like.
Modification to the Node Editor to allow the program name to always appear at the bottom of the display.
Program file 'main.js'
Modify this location:
	//rendering
	if (this.onRender) this.onRender(canvas, ctx);
	//info widget
	if (this.show_info) this.renderInfo(ctx);
Add the five lines to the info widget area:
	//rendering
	//info widget
	///////////// 4-17-2022 wjh
	ctx.clearRect(0, canvas.height - 20, canvas.width, canvas.height);
	var dpir = this.pixelRatio * this.uiRatio;
	ctx.font = "bold " + 14 * dpir + "px Arial";
	ctx.fillStyle = LiteGraph.NODE_INFO;
	ctx.fillText(this.graph.filename, 5, this.bgcanvas.height - 3 * dpir);
Comment out this line. It is a part of a different routine not required.
//  >>> ctx.fillText(this.graph.filename, 5, this.bgcanvas.height - 3 * dpir); // 4-17-2022 wjh
From this location:
LGraphCanvas.prototype.renderInfo = function (ctx, x, y) {
	x = x || 0;
	y = y || 0;
	ctx.save();
	ctx.translate(x, y);
	ctx.font = 12 * dpir + "px Arial";
	if (this.graph) {
		ctx.fillText("Total: " + this.graph.elapsed_time.toFixed(0) + " ms", 5, dpir * 15 * 1);
		ctx.fillText("FPS:" + this.fps.toFixed(0), 5, dpir * 15 * 2);
		ctx.fillText("F: " + this.frame, 5, dpir * 15 * 3);
		ctx.fillText(this.graph.blocked ? "Graph blocked" : "", 5, dpir * 15 * 4);
	} else ctx.fillText("No graph selected", 5, 13 * 1);
	ctx.restore();
15 Mar 2023   [#299] In reply to [#298]
Hi Wayne
I couldn't find the second part of your modification in my "main.js" file:
"LGraphCanvas.prototype.renderInfo = function (ctx, x, y)"
So I just added the first part and it worked.
Thank you
