Full Version: Node Wish List
Show messages:  1-16  …  177-196  197-216  217-236  237-256  257-276  277-296  297-316  …  417-425
17 Dec 2021   [#237] In reply to [#236]
Hello bemfarmer,
I am sorry I thought mLoft2 is different from Loft2, my bad!
your reply helped me :-) thank you.
18 Dec 2021   [#238] In reply to [#231]
Helloo bemfarmer,
I ran into a problem:
What should I do now?
I looked for vector3D.js and I did not find it!
18 Dec 2021   [#239] In reply to [#238]
Vector3d.js should be in the extension folder (?)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.217
Program of WayneHill.
Vector3d.js
18 Dec 2021   [#240] In reply to [#239]
Thank you,
But I ran into a new error!
Which makes me confused! I thought it should be working by now!
I have qhull3d.js in extensions folder of nodeeditor.
18 Dec 2021   [#241] In reply to [#240]
Strange results...
Note that the number of points input to the qhull need to be 3 or more, and should be an integer, (not
having a decimal point.) Otherwise, on two computer systems, home and work, the slider behaved weirdly, with mouse motion above or below the slider,
the slider would move, and weird exceptions occured. With 3+ integer number of points, the slider works fine.
So set the slider minimum to 3, and have no decimals, in its info box.
Getting your error sounds strange.
18 Dec 2021   [#242] In reply to [#241]
I asked James directly about the problem however, I'd be happy if you take a look at it too.
you can find the .nod file here: https://moi3d.com/forum/index.php?webtag=MOI&msg=9476.466
19 Dec 2021   [#243]
Here are my latest versions. Yes, the original Voronoi conversion was limited to 100 objects. Updated to 1000.
Wayne Hill
qhull3d.js
randompts.js
Vector3d.js
voronoi.js
_qhull3d.js
15 Jan 2022   [#244]
Hello all,
Could we have a search ability within Nodeeditor? (like blender when we press F3 a search window pops up)
Also when doing right-click to find a node could we have the opened windows open until we click on empty space?
16 Jan 2022   [#245] In reply to [#244]
"Could we have a search ability within Nodeeditor?"
That's all that's implemented.
16 Jan 2022   [#246] In reply to [#245]
Dear WN,
Yes I have already seen that but I meant something like search ability inside blender3D ( I don't know if you have seen it or not)
Inside Blender3D if you press F3 (a default hotkey for search within Blender3D) I meant something like that! (And I know it may sound a bit odd but somehow I miss that ability when I work with Nodeeditor)
16 Jan 2022   [#247] In reply to [#246]
Psygorn, I agree with you but there is no such thing in this program.
16 Jan 2022   [#248] In reply to [#247]
ok, :-)
But could it be made for it? because this thread is called "Node Wish List"
16 Jan 2022   [#249] In reply to [#248]
Hi Psygorn,
I would think that it's possible if someone dedicates a lot of time and effort on it.
At the moment it's not really being actively developed by anyone so it's not too likely though.
16 Jan 2022   [#250] In reply to [#248]
If you like the node approach to making geometry you might want to check out the Grasshopper system in Rhino, it's more mature and has more dedicated development resources on it.
17 Jan 2022   [#251] In reply to [#250]
Yes Node approach is interesting :-)
However, I do not have Rhino at the moment and I love MOI over other CAD modelling tools. So, I think I will wait (for developers to develop more features on Nodeeditor)
And thank you for your reply.
17 Jan 2022   [#252] In reply to [#251]
Else you have this free Nodes prog online :)
https://cables.gl
18 Jan 2022   [#253] In reply to [#252]
Interesting! and this online Nodes prog could export too?
18 Jan 2022   [#254] In reply to [#253]
I suppose yes! ;)
"Easily export your piece of work at any time. Embed it into your website or use it for any kind of creative installation."
20 Jan 2022   [#255] In reply to [#254]
Ok, thank you for the link.
11 Mar 2022   [#256]
I am attempting to simulate the Explodemove of two Voroni patterns extruded as Pilou's demo below, but with a new node on the NE (node editor, elephant some call).
Ref:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10470.4
The problem that is happening with my NE code is, everything is exploding when it should stay as a solid when moved.
If the objects are defined and applied, then the explodeMove is executed from the command line, it works fine.
The factory API for explodeMove is being guessed at by trial and error. Mostly error.
factory('explodemove', objects, distance, point);
Is there an additional parameter that says to keep the objects solid and not explode?
Thank you,
Wayne
explodeDemo.nod
ExplodeMove.js
