Full Version: Node Wish List
Show messages:  1-4  …  165-184  185-204  205-224  225-244  245-264  265-284  285-304  …  425
30 Dec 2020   [#225] In reply to [#224]
Thank you Wayne.
It is very useful information.
Message 9581.226 was deleted
12 Jan 2021   [#227] In reply to [#221]
Note, I edited the post on PVector, because it works differently from Vector3d.
It almost works in the opposite way, which caused much confusion.
If object types do not match, javascript shows an error.
The way a class is programmed determines the way it works.
Other programmers have written vector classes, and complex number classes, with instance methods, and static methods, which behave very differently from what other programmers have written. I am not aware of any standard.
So I have been doing my own complex number class, cPlex, adapting the available conflicting code.
It has to be ES5 compatible as well, to be compatible with the javascript used by MoI4.
(A complex number class is very similar to a vector2d class.)
(mathJS has the needed functions, but is extremely complicated, ES11(+/-), BigInt, etc.
Then I can finish my script.
Mixing real numbers with complex numbers makes it even more complicated.
13 Jan 2021   [#228] In reply to [#227]
Brian,
Learning both Javascript and Node Editor programming is confusing and complicated. Javascript code would work on the web browsers, but not in the Node Editor environment. That is when the version type the Node Editor uses make a difference. The scripting format of the Node Editor is very different from Javascript code. My Delaunay conversion script project changed a higher version of Javascript to a lower version to be compatible with the Node Editor. The Vector3D.js is a compilation of code from different sources. There are no documented standards to reference from for Node Editor programming. Learning from other users code, including your examples.
Wayne
13 Jan 2021   [#229] In reply to [#228]
Thank you Wayne, for the clarifications.
I see that Max initiated a vector, before making the vector equal a vector subtraction.
Arrays and objecLists get initiated before use...
Now have a better understanding of why objects do not match, in my test code.
17 Dec 2021   [#230] In reply to [#217]
Where can I find the qhull3d.nod?
17 Dec 2021   [#231] In reply to [#230]
qhull3d node seems to have been deleted(?)
Not yet integrated into Nodeeditor1.1.zip(?)
Will be located in the Objects2 menu.
(Place node in the nodeeditor extensions folder.)
qhull3d.js
17 Dec 2021   [#232] In reply to [#231]
Thank you bemfarmer :-)
17 Dec 2021   [#233] In reply to [#171]
Where is "ExtendSrf.js" to be found?
17 Dec 2021   [#234] In reply to [#233]
Hi Psygorn.
ExtendSrf.js
17 Dec 2021   [#235] In reply to [#234]
Hi WN,
Thank you.
I cannot find "Loft2.js" as well. Where can I find it?
17 Dec 2021   [#236] In reply to [#235]
Maybe try a search for +mLoft2 ?
17 Dec 2021   [#237] In reply to [#236]
Hello bemfarmer,
I am sorry I thought mLoft2 is different from Loft2, my bad!
your reply helped me :-) thank you.
18 Dec 2021   [#238] In reply to [#231]
Helloo bemfarmer,
I ran into a problem:
What should I do now?
I looked for vector3D.js and I did not find it!
18 Dec 2021   [#239] In reply to [#238]
Vector3d.js should be in the extension folder (?)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.217
Program of WayneHill.
Vector3d.js
18 Dec 2021   [#240] In reply to [#239]
Thank you,
But I ran into a new error!
Which makes me confused! I thought it should be working by now!
I have qhull3d.js in extensions folder of nodeeditor.
18 Dec 2021   [#241] In reply to [#240]
Strange results...
Note that the number of points input to the qhull need to be 3 or more, and should be an integer, (not
having a decimal point.) Otherwise, on two computer systems, home and work, the slider behaved weirdly, with mouse motion above or below the slider,
the slider would move, and weird exceptions occured. With 3+ integer number of points, the slider works fine.
So set the slider minimum to 3, and have no decimals, in its info box.
Getting your error sounds strange.
18 Dec 2021   [#242] In reply to [#241]
I asked James directly about the problem however, I'd be happy if you take a look at it too.
you can find the .nod file here: https://moi3d.com/forum/index.php?webtag=MOI&msg=9476.466
19 Dec 2021   [#243]
Here are my latest versions. Yes, the original Voronoi conversion was limited to 100 objects. Updated to 1000.
Wayne Hill
qhull3d.js
randompts.js
Vector3d.js
voronoi.js
_qhull3d.js
15 Jan 2022   [#244]
Hello all,
Could we have a search ability within Nodeeditor? (like blender when we press F3 a search window pops up)
Also when doing right-click to find a node could we have the opened windows open until we click on empty space?
