 157-176
 177-196
 197-216
 217-236
 237-256
 257-276
 277-296
 417-425
New qhull3d Node:
Based on the qhull library:
https://github.com/bjnortier/qhull
http://www.qhull.org/
I would like to thank James for helping out with testing.
Save all the files to this directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
Input:
1.  Points: At least three points to start the node.
Outputs:
1. Triangles: Line edge vectors to create planar faces.
2. Hull Pts:  The outer most points of a point cloud being input.
3: Hull Pts Objects:  The outer most object points of a point cloud being input.
Added a new Vector3d.js point class function for future projects.
Wayne
What is the the name of a "qhull" : a polyhedron ?
Qhull computes the convex hull from points.
https://en.wikipedia.org/wiki/Convex_hull
The attached image is a simple point cloud.  Red spheres are the outer-most points of the cloud making up the hull.  The lines are the triangles that make up the outer-most planes of the hull.
WOW,
I dabbled a few years ago, but gave up.
Brian
Now to try it with spherePts...
This link explains, in simple terms, the difference between static methods and instance methods,
in particular for a vector class.  Its examples with PVector (from processing), essentially show how to use the Vector3d.js class. (FALSE)
https://www.khanacademy.org/computing/computer-programming/programming-natural-simulations/programming-vectors/a/static-functions-vs-instance-methods
Note, after much confusion, the PVector examples are different from the way Vector3d is written.
So this post should be disregarded.  The classes can be written in different, conflicting ways.
Brian,
Thank you!  Max uses the Vector class on his Subdivide and the Cloth script.  It was used on the original qhull source code.
Wayne
Thank you Wayne.
I'll look at those other programs.
I have been puzzling over how to do add-on libraries, and how they are "linked", or accessed.
There seems to be multiple ways to write code.
It seems like nodeeditor/Javascript scans all the addons.
Would having ES6, (or ES11?), be of any benefit?
-Brian
Brian,
MoI's WebKit interface determines what resources are available for the Node Editor uses to ensure stability.  My Javascript version is 1.7.  ES6 or ES11 would more likely be on a different environment like a backend server Node box.  The Node Editor startup scans the scripts and begins the background services.  The scripts are scanned and linked in their filename order.
loadScripts('core', 'lang, compatibility, colors, geometry, main, editor');
loadScripts('nodes', 'macros, basic, logic, points, curves, solids, construct, transform, objects, interface');
loadScripts('nodes/extensions/libs', '*');
loadScripts('nodes/extensions', '*');
loadScripts('core', 'init, ext.*');
If you want to build a library calling other Javascript files, they have to be scanned (note filename order) before they are available for the other libraries to use.
Example directory:
1test.js
2test.js
3test.js  (uses 1test.js and 2test.js and 4test.js)
4test.js
3test.js can use 1test.js and 2test.js libraries but not 4test.js library because it has not been scanned. Error will trigger on a missing script.  It is not missing.
4test.js will have to be renamed to 0test.js in both 3test.js and it's filename.
New listing:
0test.js
1test.js
2test.js
3test.js  (uses 1test.js and 2test.js and 0test.js)
Wayne
Thank you Wayne.
It is very useful information.
Message 9581.226 was deleted
Note, I edited the post on PVector, because it works differently from Vector3d.
It almost works in the opposite way, which caused much confusion.
If object types do not match, javascript shows an error.
The way a class is programmed determines the way it works.
Other programmers have written vector classes, and complex number classes, with instance methods, and static methods, which behave very differently from what other programmers have written.  I am not aware of any standard.
So I have been doing my own complex number class, cPlex, adapting the available conflicting code.
It has to be ES5 compatible as well, to be compatible with the javascript used by MoI4.
(A complex number class is very similar to a vector2d class.)
(mathJS has the needed functions, but is extremely complicated, ES11(+/-), BigInt, etc.
Then I can finish my script.
Mixing real numbers with complex numbers makes it even more complicated.
Brian,
Learning both Javascript and Node Editor programming is confusing and complicated.  Javascript code would work on the web browsers, but not in the Node Editor environment.  That is when the version type the Node Editor uses make a difference.  The scripting format of the Node Editor is very different from Javascript code.  My Delaunay conversion script project changed a higher version of Javascript to a lower version to be compatible with the Node Editor.  The Vector3D.js is a compilation of code from different sources.  There are no documented standards to reference from for Node Editor programming.  Learning from other users code, including your examples.
Wayne
Thank you Wayne, for the clarifications.
I see that Max initiated a vector, before making the vector equal a vector subtraction.
Arrays and objecLists get initiated before use...
Now have a better understanding of why objects do not match, in my test code.
Where can I find the qhull3d.nod?
qhull3d node seems to have been deleted(?)
Not yet integrated into Nodeeditor1.1.zip(?)
Will be located in the Objects2 menu.
(Place node in the nodeeditor extensions folder.)
qhull3d.js
Thank you bemfarmer :-)
Where is "ExtendSrf.js" to be found?
Hi Psygorn.
ExtendSrf.js
Hi WN,
Thank you.
I cannot find "Loft2.js" as well. Where can I find it?
Maybe try a search for +mLoft2   ?
 157-176
 177-196
 197-216
 217-236
 237-256
 257-276
 277-296
 417-425
