41-60
61-80
81-100
101-120
121-140
141-160
161-180
421-425
A-W-E-S-O-M-E !!!
Happy New Year Everyone,
Here's another proposal for a new node:
Noise Generator Node
There are lots of applications for a 2D Perlin Noise fields for natural forms;
for example ocean wave simulation :
http://www.alexlorman.com/oceanwavesimulation
Also it would be useful for random transformation the transition smoothly.
Of course 2D Noise fields could be imported as images into ImgSampler, however if they could be generated in NE
there would allow greater control and possibility of animation
Here is interest blog post on Perlin Noise in JavaScript
http://asserttrue.blogspot.com/2011/12/perlin-noise-in-javascript_31.html
An online 2D peril noise generator
http://www.kitfox.com/projects/perlinNoiseMaker/index.html
https://www.instagram.com/nodeology/Image Attachments:
Message 9581.103 was deleted
I believe that this new year about Elephant will be some laborious for me! :)
Happy new year!
PS some ideas of nodes! (look this free prog: JsPlacement)
https://windmillart.net/?p=jsplacement
New Perlin Noise Node release
This node uses Ken Perlin's routine for generating PerlinNoise(c) data points.
Copy the PerlinNoise.js and perlinnoisefn.js function to this directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
I would like to thanks James for helping out with testing.
Wayne
Ref:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.102
Updated node. Jan 9 2020
Hi All,
Just putting up a NODE wish using the new image sampler would it be possible to create a node that can generate this sort of image based on input lines like supplied. Using MAX's FATLINES to create variable width lines based on those 2 variables linework overlaid by image.
Thanks Alex
FatLines Node
The proposed node would be analogous to Max's Fatlines script:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7594.31
Since there is an elevated interest in voronoi3d at the moment,
http://moi3d.com/forum/index.php?webtag=MOI&msg=7177.177
I thought it would be worth adding it to the wishlist.
Voronoi3d Node
Message 9581.109 was deleted
Updated ImgSampler
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57
Wayne
Max Smirnov's Voronoi for the Node Editor
Based on his Voronoi script located at:
http://moi.maxsm.net/files/scripts/
Moi discussion reference:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.5
Save voronoi.js file to this directory:
Wayne
Excellent and all ready made for the Repository! Bravo!
Hyper cool!
Does the ImageSampler has limitations ?
Format JPG, PNG ...?
Colors, Grey Levels, B&W, ...?
Size x,y ?
Does it possible to put a Version's Number of Extension, or a date...?
Because it's a mess for know what is the last one! :)
in the title for example (Titre = Title Fr / Eng ;)
I don't see PerlinNoise, PerlinNoiseFn ...
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.105
...in the Updated NodeEditor ?
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
RoundCrns Node
This is quite self-explanatory: the proposed node would apply rounding to corners of closed polylines/n-gons. (if it also worked on open polylines, that would be a bonus) This is different to "DelCorners" script as these corners would have a user determined radius.
I often use 2 x Construct2/offset nodes in sequence to achieve this result by offsetting inwards then offsetting outwards with "rounded" mode. Although this is mostly a workable solution it fails with small shapes and is not multiprocessing.
A great weekend to all
The ImgSampler is limited by the processing time and memory it takes to make really large images.
It works with JPG, BMP, PNG, GIF and possibly other formats not tested.
All image colors are converted to grayscale during the processing. Size capacity was not tested. It is capable of very large renderings and will take time and memory to process them.
The latest version has the Crvs output and the image size below. Version numbering would be a good idea because of all the update improvements and more in the future.
PerlinNoiseFn is the function library for PerlinNoise. It does not show in the menu.
Wayne
THX for infos!
Hi James :)
Well...I'm very happy to see that since when (years ago) I started talking about Moi as a "2D workflows" tool, I'm very happy to see that with the AWESOME Node Editor and with your wonderful job now Moi is becoming a very very powerful 2D editor. A very specialized one indeed.
Now, I think that what is still really missing, is an easy and friendly UX.
For example: I need to round the corners of a closed poly line using that particular N.E. script? Ok. All I have to do is to push a BUTTON in the UI or fire a key shortcut, and that's it.
Unfortunately at present, i have to 1) open the N.E. Editor, 2) Load a particular script 3) Select the proper objects 4) Run the script 5) Close the N.E. UI
It could be awesome if N.E. would be much more tightly integrated with Moi's environment.
But I guess that for this update only Max would put his hands on it :)
New Random Point Node
This point generator creates random points in 3D space. On the surface of an Ellipsoid. Or inside an ellipsoid.
Either X,Y, or Z values can be set to zero for a plane point area or a line of random points.
Wayne
New Delaunay Node:
This node uses a modified delaunator javascript library from:
https://github.com/mapbox/delaunator
The output Lines is for a single line graphics
The Triangles output generates triangles that can be used for planar face surfaces.
Copy the delaunay.js and delaunator.js files to the directory:
I would like to thank James for helping out with testing and design recommendations.
Ref:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.8
Wayne
Message 9581.120 was deleted
41-60
61-80
81-100
101-120
121-140
141-160
161-180
421-425
