21-32
Hi Wheel,
> but am having problems getting it to work.
Could you please post your modified scripts here as an attachment? That will make it easier to take a look at them and see what is not working in it.
> Should the hotkey settings be the same for Petrs and Michaels
> versions , the four arrow keys and page up and down ?
Yeah, if I remember right I think that the shortcut key settings were the same.
Hi, here is the tweaked version of your script . Thanks for looking.
Nudge.js
Hi Wheel - your modified script seems to work ok for me over here.
Maybe it's a setup problem?
That Nudge.js file should be copied into the \commands sub-folder underneath MoI's main installation folder (like C:\Program Files\MoI 1.0\commands).
Then under Options / Shortcut keys, you'll need settings like this:
| Key | Command |
| DownArrow | Nudge Down |
| UpArrow | Nudge Up |
| LeftArrow | Nudge Left |
| RightArrow | Nudge Right |
| PageUp | Nudge ZUp |
| PageDown | Nudge ZDown |
Note one subtle thing here is that the left-side "Key" part does not have a space in it, like DownArrow is all one word with no spaces inside it. While the "Command" part does have a space between Nudge and the second word.
sorry what is a "Nudge" and his function?
Hi Pilou - Nudge means to move by a small amount.
The Nudge command allows you to set up keys such as the arrow keys to move around objects or points by a small amount on every key press.
Thx because my dico has given me somthing like that "a knock elbow" :)
Sorry if it was allready asked, but is it possible to know which viewport the mouse is over, and modify the direction of the nudge according to it.
I mean if:
- the mouse is over the top view, right and left arrow 'nudge' on the x axis, up and down arrow on the z axis
- the mouse is over the front view, right and left arrow 'nudge' on the x axis, up and down arrow on the y axis
- the mouse is over right view, right and left arrow 'nudge' on the z axis, up and down arrow on the y axis
do you see the idea ... looks more natural for me, but maybe I'm alone :P
of course the perspective view require the 6 keys, like it is mapped now (page up page down for y move)
Hi PaQ,
I think the version attached to this message should do that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=952.6
Oh, great! That's exactly what I was looking for!
Well, maybe not exactly, because IDL isn't quite my favorite thing in the world to read, but yes, thank you -- that'll be quite useful. :-)
/Ella
Hi Ella, I have also created a wiki page here:
http://moi3d.com/wiki/Scripting which can be used as a central place to record any information, tips, descriptions, etc... about scripting. Please feel free to add stuff there.
Nudge script have an issue:
01. invoke bevel.
02. use Tab key to change gui focus from "Radius" to "Shape".
03. use RMB or Enter to apply bevel
04. Select object and try to use Up & Down Nudge commands.
Up and Down Nudge doesn't work after this. Until you press Tab key and then Enter.
It happens i guess because gui focus stak somwere on already closed bevel "Shape" gui.
Its interesting that Lef and Right Nudge still works.
It's not a huge problem at all but kinda annoying.
Hi Bravlin, thanks for reporting this Nudge bug, I was able to repeat it here. It was a bug in the dropdown control where it wasn't getting detached from focus handling in that situation. I've got a fix in place for the next v4 beta.
21-32
