35-54
55-74
75-94
95-114
115-134
135-154
155-174
495-503
Very very mysterious!!!
Now that works like that must be! No need to insert an additional Node! :)
Added Curve (English)
http://moiscript.weebly.com/curves.html
Added Polyline (English)
Ok Section Curves (13 items) in English is done...so now the French one...will be easier and faster! :)
Big suspense for the Next Section ! :)
Big Section "Curve" in French done! :)
Now Section "Objects"
Clone done (English French)
http://moiscript.weebly.com/objects.html
Node Selected (English French)
Node Get by Name (English French)
Not yet Updated so OutPut = "--"
Node Get by Style (English French) (sorry I don't why Styles are listed in French on the English Elephant version!!! )
Again in the fog! :)
How to extract "Points" from the OBJToArray Point for see them ?
No yet result with the "Extract"...so try that but...
ConvertPts don't want to show them! (orange square! :(
Before the light of the ObjToArray :) (possible i make a missunderstanding of this Node)
here the last Node BoundingBox of the Object section (English French)
Global view of the Native Nodes
Useful for the Input / OutPut colors! ;)
ObjToArray is totally mysterious for me!
And surrely ConvertPoint! :)
(Selected (0) is normal I made the ScreenShot between 2 tests )
How Extract all from a selection in one pass ?
Selected > ObjtoArray > extractPts > Output
PinkDot represent pointarray class, and contain many properties, including "raw" points, e.g.(x,y,z), AND frames and scales(?) and angles...
GoldDot points are MoI's geometry form of points, which can be added to the geometry database and displayed in MoI. (Object Lists)
GoldDot points can have styles, names, etc.
<<Selected> ObjtoArray > extractPts > Output
I have a cube selected
Not yet working! (square orange) and not sure that takes all points...(maybe also i don't use good nodes after the Extract)
This is working. Maybe right click on Selected and Update. The extractPts is in the Objects2 node
New test only one point (before reading your last post)
Ah OK Cool! you pass not by the "Array" :)
So what is the "Pink Array" of the "ObjTo Array" ?
Just a little Thing : The "ExtractPts" is not in the Native Nodes!!!
I am only on the Native Nodes for the moment! ;)
So maybe that is not possible with only Native Nodes ?
And always want to know what is exactly the Pink "Array" of the Native Node "ObjToArray" :)
More easy :)
Node Loft (English French)
http://moiscript.weebly.com/construct.html
Node Sweep (English French)
35-54
55-74
75-94
95-114
115-134
135-154
155-174
495-503
