Show messages:  1-18  19-38  39-58  59-78  79-98  99-118  119-138  139-158  …  499-503
3 Sep 2019   [#79]
Node Arc 3Pts (English)
http://moiscript.weebly.com/curves.html
4 Sep 2019   [#80]
Added Arc Center (English)
4 Sep 2019   [#81]
Added Circle Dia (English)
Curiously there is not Input inside the Info Panel!
4 Sep 2019   [#82]
Added Circle 3 Pts (English) Input datas only by Nodes ! Not Possible by Info Panel !
4 Sep 2019   [#83]
Added Ellipse Center (English)
4 Sep 2019   [#84]
Added Ellipse 3 Pts (English)
Maybe a little glitch on the "Z" Point drawing? (not on the ellipse perimeter! )
4 Sep 2019   [#85]
I am blocked with the Nodes Curves & Polylines for Input datas ! ???
If you have some lights about that! :)
4 Sep 2019   [#86] In reply to [#85]
Look at the curves.js file for the geometry definitions.
// Curve
function Curve()
this.addInput("In","pointarray");
this.properties = { mode:["Curve", "Curve", "Interpcurve"], closed:["No", "No", "Yes"]};
// Polyline
function Polyline()
this.properties = {closed:["No", "No", "Yes"]};
Wayne
4 Sep 2019   [#87] In reply to [#85]
The 3 colours of wires and connectors (inputs & outputs) represents the 3 data types:
GREEN = number data (numbers or numArrays)
PINK = point data (points or pointArrays)
YELLOW = objects (curves, surfaces or bReps)
So Curve & polyline nodes inputs are PINK and hence point arrays (minimum length of 2)
Hope this makes sense.
PS Keep up the good work.
4 Sep 2019   [#88]
Yes I am totally agree with you but the problem is that i don't find the good "native" Nodes for that! :)
(simple way like that or more complex)
I must miss something trivial!
4 Sep 2019   [#89] In reply to [#81]
So Green inputs may have default values in the info window(?) Pink pointarray inputs do not have such default values in the info window (?)
Also Vertikal should be changed to Vertical :-)
4 Sep 2019   [#90] In reply to [#89]
Vertikal is Max ! ;)
<< Pink pointarray inputs : what is the name of this node (if it's a native one)
Polyline has no case for input list of something
4 Sep 2019   [#91] In reply to [#88]
For example:
Use Point node object output, as input to ObjToArray.
Use 3 Progression nodes with different settings, as input to Point node x, y, z.
4 Sep 2019   [#92]
Sorry I am in total foggy mood! :)
Say I draw 4 Points : how to transform them in Polyline or Curve ?
(or Maybe Nodes Polyline or Curve is not made for that ?
My OutPut stays desesperately "orange" even with hundred of tests/errors! :)
PS and how gives the good order of them ?
4 Sep 2019   [#93]
OK I have the curve! :)
It's more problematic for the Polyline : problem of order of points!
4 Sep 2019   [#94]
OK I have the Polyline also! :)
Maybe Node "MovePoint" will be more simple with dx,dy,dz =0 than TransformPts
Not sure if all that is very orthodox but that works! :)
Order of points is good when you click one by one for select them for a few selection
Many more problematic when you have hundred of them!
4 Sep 2019   [#95]
Very very mysterious!!!
Now that works like that must be! No need to insert an additional Node! :)
4 Sep 2019   [#96]
Added Curve (English)
4 Sep 2019   [#97]
Added Polyline (English)
4 Sep 2019   [#98]
Ok Section Curves (13 items) in English is done...so now the French one...will be easier and faster! :)
Big suspense for the Next Section ! :)
