Show messages:  1-11  12-31  32-51  52-71  72-91  92-111  112-131  132-151  …  492-503
3 Sep 2019   [#72]
Ok all is mastered! (my headache also! :)
And of course that change if you modify the Points modes itselves! :)
So 2 (modes start pts) * 2 (modes end pts) * 5 (modes lines) = 20 possible combinaisons of modes! (for the moment)
here only the "Pts" so 4 variants with "Long Lines"
3 Sep 2019   [#73]
Added Node Line (English) + paradigmatic Modes :)
http://moiscript.weebly.com/curves.html
3 Sep 2019   [#74]
Added Node Circle (English)
3 Sep 2019   [#75]
Added Node Rectangle (English)
3 Sep 2019   [#76]
Added Polygon (English)
3 Sep 2019   [#77]
Added Star (English)
3 Sep 2019   [#78]
I have some troubles with the Nodes Curve, Polyline! :)
3 Sep 2019   [#79]
Node Arc 3Pts (English)
4 Sep 2019   [#80]
Added Arc Center (English)
4 Sep 2019   [#81]
Added Circle Dia (English)
Curiously there is not Input inside the Info Panel!
4 Sep 2019   [#82]
Added Circle 3 Pts (English) Input datas only by Nodes ! Not Possible by Info Panel !
4 Sep 2019   [#83]
Added Ellipse Center (English)
4 Sep 2019   [#84]
Added Ellipse 3 Pts (English)
Maybe a little glitch on the "Z" Point drawing? (not on the ellipse perimeter! )
4 Sep 2019   [#85]
I am blocked with the Nodes Curves & Polylines for Input datas ! ???
If you have some lights about that! :)
4 Sep 2019   [#86] In reply to [#85]
Look at the curves.js file for the geometry definitions.
// Curve
function Curve()
this.addInput("In","pointarray");
this.addOutput("Out","objectlist");
this.properties = { mode:["Curve", "Curve", "Interpcurve"], closed:["No", "No", "Yes"]};
// Polyline
function Polyline()
this.properties = {closed:["No", "No", "Yes"]};
Wayne
4 Sep 2019   [#87] In reply to [#85]
The 3 colours of wires and connectors (inputs & outputs) represents the 3 data types:
GREEN = number data (numbers or numArrays)
PINK = point data (points or pointArrays)
YELLOW = objects (curves, surfaces or bReps)
So Curve & polyline nodes inputs are PINK and hence point arrays (minimum length of 2)
Hope this makes sense.
PS Keep up the good work.
4 Sep 2019   [#88]
Yes I am totally agree with you but the problem is that i don't find the good "native" Nodes for that! :)
(simple way like that or more complex)
I must miss something trivial!
4 Sep 2019   [#89] In reply to [#81]
So Green inputs may have default values in the info window(?) Pink pointarray inputs do not have such default values in the info window (?)
Also Vertikal should be changed to Vertical :-)
4 Sep 2019   [#90] In reply to [#89]
Vertikal is Max ! ;)
<< Pink pointarray inputs : what is the name of this node (if it's a native one)
Polyline has no case for input list of something
4 Sep 2019   [#91] In reply to [#88]
For example:
Use Point node object output, as input to ObjToArray.
Use 3 Progression nodes with different settings, as input to Point node x, y, z.
