Show messages:  1-3  4-23  24-43  44-63  64-83  84-103  104-123  124-143  …
2 Sep 2019   [#64]
One more try :-)
Switch node:
The Output is connected to either the top input, or else the bottom input, depending upon:
Switch mode:
Left click toggles between top input and bottom input.
Changing to Button mode, in info window, connects the top input.
Button mode:
The pre-existing connection is with the top input.
Left click with HOLD, connects the bottom input, until hold is released. Then the top input is re-connected.
Pilou, you are doing an excellent job!
2 Sep 2019   [#65] In reply to [#64]
Added these last precisions with the Switch mode from you for be exhaustive :)
3 Sep 2019   [#66]
Some infos about these Modes : Long, short, cross, average, repeat (here for the node Line )
It's for Arrays of values or it's another things ?
3 Sep 2019   [#67] In reply to [#66]
Max did some explaining in the nodeeditor thread a while back.
About 8 months ago, I went through the thread, and copied portions of relevant explanations (documentation) to a notepad++ file.
(Whether it was understood or not :-)
I think Karsten made some explanations as well...
3 Sep 2019   [#68] In reply to [#67]
These selection modes must be known by computer programmers:
...Looping Through Multiple Lists
...descends through lists combining all elements into one ... dim=c(3,4,2); elements of x recycle if x is not long enough...
Google: "combining multiple lists Long, short, cross" yields Lacing type (short, long, cross), in programming.
Then Lacing becomes how to tie shoes...:-)
3 Sep 2019   [#69] In reply to [#67]
Ok that is that for the Array of values that you input inside the Panel info (and i suppose also for multiple selection)
Now rest to have the little animations for cross, average, repeat !
The funny of that is you have these same modes ( or less) for the Points of the lines itselves! (not only for the lines)
So many combinaisons possible! :)
3 Sep 2019   [#70]
I begin to understand! :) here for cross...each start line point go to each end line point (if Points itselves are all "Long" ! )
3 Sep 2019   [#71]
Ok I have nailed it! :)
All points are "Long"
3 Sep 2019   [#72]
Ok all is mastered! (my headache also! :)
And of course that change if you modify the Points modes itselves! :)
So 2 (modes start pts) * 2 (modes end pts) * 5 (modes lines) = 20 possible combinaisons of modes! (for the moment)
here only the "Pts" so 4 variants with "Long Lines"
3 Sep 2019   [#73]
Added Node Line (English) + paradigmatic Modes :)
http://moiscript.weebly.com/curves.html
3 Sep 2019   [#74]
Added Node Circle (English)
3 Sep 2019   [#75]
Added Node Rectangle (English)
3 Sep 2019   [#76]
Added Polygon (English)
3 Sep 2019   [#77]
Added Star (English)
3 Sep 2019   [#78]
I have some troubles with the Nodes Curve, Polyline! :)
3 Sep 2019   [#79]
Node Arc 3Pts (English)
4 Sep 2019   [#80]
Added Arc Center (English)
4 Sep 2019   [#81]
Added Circle Dia (English)
Curiously there is not Input inside the Info Panel!
4 Sep 2019   [#82]
Added Circle 3 Pts (English) Input datas only by Nodes ! Not Possible by Info Panel !
4 Sep 2019   [#83]
Added Ellipse Center (English)
