Show messages:  1-16  17-36  37-56  57-76  77-96  97-116  117-136  …  497-503
2 Sep 2019   [#57] In reply to [#56]
The Switch in switch mode maintains the connection between the input the internal wire is currently touching, and the output.
Left mouse clicking the Switch body changes the connection to the other input. After finishing the click, the connection with the other input is maintained,
until another left mouse click is performed.
When the Switch is in button mode, without being manipulated with the mouse, the connection is with the upper (top) input.
Then, in button mode, holding down the left mouse "key button" on the switch icon body, causes the connection to change to the lower (bottom) input.
When the user ceases to hold down the left mouse "key button" on the switch icon body, the connection reverts to the upper (top) input.
Your dynamic picture should be redone, because you are failing to select the switch mode, and you are only showing the button mode function.
2 Sep 2019   [#58]
There is a lack of symmetry in the switch action.
If in switch mode, with the switch set to connecting the lower input, changing to button mode immediately
changes the connection to the upper input.
Maybe the .js code should be changed to restore the symmetry?
2 Sep 2019   [#59] In reply to [#58]
It is hard to come up with an electrical analogy.
Switch mode is like a single pole, "3 way switch", which normally has 3 terminals. Two terminals are the "travelers", the third terminal is the output.
Two 3 way switches are used to light a hallway, alternately from either end of the hallway.
Button mode is like the crush ice button on an appliance, which only runs the blade when held pressed in. But this
analogy lacks a function for the upper input, which is null. Some kind of logic gate might be better.
The clutch on a car is an example of button mode? Un-pushed for normal travel, pushed in for changing gears...
2 Sep 2019   [#60]
@Bem
Thanks for all these infos! I will study that for make a little more comprehensive animation! :)
2 Sep 2019   [#61]
ok I believe that I have understood! :)
Mode Switch = perpetual change of position of the actual state until the next click for a new rotating change.
Mode Button = only change the top state until the mouse is not released without rotating change at the release
2 Sep 2019   [#62] In reply to [#61]
Mode "Switch":
A left click on the body of the node changes the input state to the opposite configuration. The state is latched / fixed. (is semi-permanent).
---Pre-existing top input state becomes bottom input state. And stays in that state until some other mouse action.
---Pre-existing bottom input state becomes top input state. And stays in that state until some other mouse action.
Mode "Button":
A Left click and HOLD, changes from the top input state to the bottom input state.
Upon release of the Left click Hold, the top input state is restored. (not exactly a Toggle?)
Mode Change in the info window:
If mode is changed from Switch mode to Button mode:
either I. A pre-existing top input state is preserved.
or else II. A pre-existing bottom input state changes to top input state. (Which is latched / fixed.)
(So it is not possible to be in button mode and have click and Hold engaged, and be in the top input state.)
(So many words to describe "simple" switch:-)
(Toggle is a pretty good word. Permanent is perhaps not so good a description. I used semi-permanently, perhaps not so good either. Latches is a pretty good word.)
Latching a gate closed does not permanently close the gate. But does close the gate until some other action occurs.
latch, latching
fasten (a door or gate) with a latch.
"she latched the door carefully"
synonyms: fasten, secure, make fast, bar, bolt; More
ELECTRONICS
(of a device) become fixed in a particular state.
Toggle indicates a change of state.
verb
1.
COMPUTING
switch from one effect, feature, or state to another by using a toggle.
"the play/pause button toggles between those functions"
The French words are up to you :-)
2 Sep 2019   [#63] In reply to [#62]
For stay concise i have put a link to your description! ;)
And put this animation...in fact that's like an electric game train!
Mode "button" is for speedy distress cases! Like detach a wagon! :)
2 Sep 2019   [#64]
One more try :-)
Switch node:
The Output is connected to either the top input, or else the bottom input, depending upon:
Switch mode:
Left click toggles between top input and bottom input.
Changing to Button mode, in info window, connects the top input.
Button mode:
The pre-existing connection is with the top input.
Left click with HOLD, connects the bottom input, until hold is released. Then the top input is re-connected.
Pilou, you are doing an excellent job!
2 Sep 2019   [#65] In reply to [#64]
Added these last precisions with the Switch mode from you for be exhaustive :)
3 Sep 2019   [#66]
Some infos about these Modes : Long, short, cross, average, repeat (here for the node Line )
It's for Arrays of values or it's another things ?
3 Sep 2019   [#67] In reply to [#66]
Max did some explaining in the nodeeditor thread a while back.
About 8 months ago, I went through the thread, and copied portions of relevant explanations (documentation) to a notepad++ file.
(Whether it was understood or not :-)
I think Karsten made some explanations as well...
3 Sep 2019   [#68] In reply to [#67]
These selection modes must be known by computer programmers:
...Looping Through Multiple Lists
...descends through lists combining all elements into one ... dim=c(3,4,2); elements of x recycle if x is not long enough...
Google: "combining multiple lists Long, short, cross" yields Lacing type (short, long, cross), in programming.
Then Lacing becomes how to tie shoes...:-)
3 Sep 2019   [#69] In reply to [#67]
Ok that is that for the Array of values that you input inside the Panel info (and i suppose also for multiple selection)
Now rest to have the little animations for cross, average, repeat !
The funny of that is you have these same modes ( or less) for the Points of the lines itselves! (not only for the lines)
So many combinaisons possible! :)
3 Sep 2019   [#70]
I begin to understand! :) here for cross...each start line point go to each end line point (if Points itselves are all "Long" ! )
3 Sep 2019   [#71]
Ok I have nailed it! :)
All points are "Long"
3 Sep 2019   [#72]
Ok all is mastered! (my headache also! :)
And of course that change if you modify the Points modes itselves! :)
So 2 (modes start pts) * 2 (modes end pts) * 5 (modes lines) = 20 possible combinaisons of modes! (for the moment)
here only the "Pts" so 4 variants with "Long Lines"
3 Sep 2019   [#73]
Added Node Line (English) + paradigmatic Modes :)
http://moiscript.weebly.com/curves.html
3 Sep 2019   [#74]
Added Node Circle (English)
3 Sep 2019   [#75]
Added Node Rectangle (English)
3 Sep 2019   [#76]
Added Polygon (English)
