408-427
428-447
448-467
468-487
488-503
Hi James,
still the same issue.
I think its the voronoi node I can only generate in a rectangle up to 100 x 100.
If I take your original nod and just adjust the Y constant from 200 down to 100 all works fine.
The photo shows the results when reducing the Y value.
Barry
.png)
Thanks Barry,
Actually that rings a bell.
Try replacing your voronoi.js file in extensions folder with the one attached.
It is possible that mine is an updated version
See how this works with my first version of NOD file
https://www.instagram.com/nodeology/Attachments:
voronoi.js
Hi James,
no go with that voronoi node.
Your original nod file works by reducing the X & Y constants to X 35 Y 50 plus reducing the voronoi space to 0.5.
Barry
James Voronoi Torus.nod
Barry,
That's odd!
If you look at attached image, you can see that the dimensions of generated voronoi are well over 100 units.
Did you shut down Moi3d.app & restart before reloading NOD file?
And how did you do that?
Hi James,
yes my mistake hadn't closed moi your new voronoi node works thank you.
Do you have the same issue with the randompts not updating in the panel ?
Many thanks
Barry
Barry,
I'm not sure what you mean.
Hasn't the issue of unpatterned half torus been solved?
Hello again James,
I'd be happy if you guide me here as well. :-)
Happy weekend :-)
Psygorn,
Replace voronoi.js file in app support/Moi/nodeeditor/nodes/extensions/
with file attached.
voronoi.js
Hi James,
yes the torus node works perfectly.
My query is the randompts inputs do not update in the info panel but updates correctly in the model.
See photo.
Also could you upload the extendsrf nod please Wayne as removed it.
Again many thanks.
Barry
.png)
Hi James .
I also show it that way, but it's easy to fix. The files are different, the difference is only two lines, attached a screenshot. Now everything works well.
Barry,
Ahh yes, I've never notice the the info panel does not update properly.
This must be a glitch in the script.
ExtendSrf.js
Hi James,
And thank you. it works fine.
Hi Barry-H.
Now the data will be updated, I added the necessary lines in the script.
randompts.js
Hi Wayne,
thanks works perfect.
Have a good Xmas
Barry
<< How do you make that ?
@Psygorn
Just launch the James .nod voronoi
Copy / Move /Scale some times the result (half full / voronoi )
Then export as OBJ
and input by Drag and Drop files into the crazzy free SPline! :)
you can make UVs inside Spline
https://spline.design (better than SketchFab because you have a true real 360° on the 3 axes! )
some animations are started by click on the object! ;)
(background & Ground are Spline but of course all can be made inside MOI3D before OBJ exportation)
PS and of course the crazzy textures by the free online Vervette SandBox ! :)
http://www.taron.de/Vervette/sandbox/
Hi Barry-H.
Wayne does write good scripts, I just added a few lines.
Perhaps this was done on purpose, when you turn off the input returns the default data.
Hi WN
apologies for name mix up but thanks again for sorting the issue out.
Barry
Hello all,
How could we have constant with Array input?
please take a look at James work here:
https://www.instagram.com/p/CYv6vIlP0Zy/
I tried to reconstruct it but I get an Error!
Node file attached
Moebius Strip.nod
Psygorn
The constant node contains a 2 number array: 0,6.283 (0,2*PI)
See attached NOD file .
moebiusMesh.nod
408-427
428-447
448-467
468-487
488-503
