Show messages:  1-14  …  315-334  335-354  355-374  375-394  395-414  415-434  435-454  …  495-503
25 Nov 2019   [#375]
Thx to Karsten for enlight me on this new one :) Some others in waiting holes! :)
See http://moiscript.weebly.com/biblio-elephant.html for see the missing holes!
Section ArraysEXT
BundleArray
English
http://moiscript.weebly.com/arraysext.html#bundlearray
26 Nov 2019   [#376]
Section Curves2
Spiral Node
English
http://moiscript.weebly.com/curves2.html#spiral
26 Nov 2019   [#377] In reply to [#376]
Negative numbers on Turns will reverse spiral direction.
Wayne
26 Nov 2019   [#378] In reply to [#377]
Modified! :
If you have any lights about my not repositored nodes shown don't hesitate!
Because names of them is not sufficient for explain what they do for me! :(
8 Dec 2019   [#379]
Section Point2
GetCrvSFrame Node
Will be in English :)
http://moiscript.weebly.com/point2.html#getcrvsframe
14 Jan 2020   [#380]
Happy new year and come back! :)
A little rusted! :D Links will arrive as soon as possible! ;)
Section Object2
Clone4 Node by Brian
English
http://moiscript.weebly.com/objects2.html#clone4
21 Jan 2020   [#381]
Final Links will be made in some times...
General Repository French / English http://moiscript.weebly.com/biblio-elephant.html
Voronoï Node (By Wayne)
English
http://moiscript.weebly.com/objects2.html#voronoi
23 Jan 2020   [#382]
Perlin Node BY Wayne
Extentions / Object2
English
http://moiscript.weebly.com/objects2.html#perlinnoise
23 Jan 2020   [#383]
ImgSampler by Wayne
English
http://moiscript.weebly.com/objects2.html#imgsampler
26 Jan 2020   [#384]
NodeList core extension (an improved version of bundeled ext.mylib extension)
Added Drag and drop support
http://moi.maxsm.net/files/nodeeditor/ext.nodelist.js
Copy it to nodeeditor/core directory (ext.mylib.js can be removed)
26 Jan 2020   [#385] In reply to [#384]
Thanks a lot Max!
Also...when will you put your hands on the CORE of N.E. to add some new substantial feature?
Are you waiting the official release of V4?
Have a nice day :)
26 Jan 2020   [#386]
Don't know if it's a bug ?
When I press Load in the NodeEditor , and then press Cancel in the Windows of download file
i have this... (so I select no file)
26 Jan 2020   [#387] In reply to [#386]
Same error is encountered here.
I vaguely recall it occurring several months ago (?)
26 Jan 2020   [#388]
Max's nodelist is very nice.
I finally clicked on the icon of three vertical bars. I'm not sure of the official name. Hamburger bar seems populer :-)
So drag the selected node (or macro) to its desired located.
Clicking, and then click_drag leaves a copy of the node, in shadow, behind the nodelist. (slightly objectionable?, or ?)
Click the three vertical bars again to exit nodelist.
https://stackoverflow.com/questions/34755666/what-is-the-hamburger-menu-icon-called-and-the-three-vertical-dots-icon-called
Eagerly awaiting official names for all of these icons. There are lots of unknown icons on my android tablet, which is connected to Verizon wireless, and also to home network.
It allows MoI forum access, but doesn't quite work like a Windows 10 machine, so is a bit awkward.
p.s. Home network is hooked up to via a persons WIFI "modem", not the PC.
26 Jan 2020   [#389] In reply to [#388]
@ Bem You can use some free progs like https://www.realvnc.com for use MOi on your Androïd Tablett!
(the only allowing the 3 mouse buttons for me - the other like Google Remote manage only the left click! )
Even put a Mouse with an OTG USB connector !
And keep or not the fingers "Touch" effect!
= the dream :)
PS and of course any progs running on your PC with only limitations of your PC! (15 meters)
That is the 21 century!
27 Jan 2020   [#390] In reply to [#389]
Thank you Pilou for the tips.
27 Jan 2020   [#391] In reply to [#386]
Hi Pilou
>> When I press Load in the NodeEditor , and then press Cancel in the Windows of download file i have this... (so I select no file)
I fixed this bug. Thanks
27 Jan 2020   [#392] In reply to [#391]
Excellent! ;)
30 Jan 2020   [#393]
Links added! :) https://moi3d.com/forum/index.php?webtag=MOI&msg=9476.381
English
30 Jan 2020   [#394]
Delaunay Node by Wayne
English
http://moiscript.weebly.com/objects2.html#delaunay
