Show messages:  1-3  …  304-323  324-343  344-363  364-383  384-403  404-423  424-443  …
22 Oct 2019   [#364]
Aaaaah...many tests and headaches before to undertand that the first array's index was 0 and not 1 ! :D
So after that all works like a charm! :)
Section Objects2
SelectedExt
English
http://moiscript.weebly.com/objects2.html#selectedext
22 Oct 2019   [#365]
Section Objects2
BrepNameSubObjects Node
English
http://moiscript.weebly.com/objects2.html#brepnamesubobjects
23 Oct 2019   [#366]
Curious : no need Selected, OutPut Nodes just Click on the SimpleBridge Node!
Section SubD
SimpleBridge Node
English
http://moiscript.weebly.com/subd2.html#simplebridge
23 Oct 2019   [#367]
I am perplex about this node!
24 Oct 2019   [#368] In reply to [#367]
Hello Pilou,
the stuff in subD is unfinished. It is a while ago that I was working on it. So don't think about this nodes.
I hope that some day someone will pick up the ideas and we can finish it.
Have a nice day
Karsten
24 Oct 2019   [#369] In reply to [#368]
...so wait and see! :)
else a new one
Section Objects2
RemoveDupCrv Node
English
http://moiscript.weebly.com/objects2.html#removedupcrv
10 Nov 2019   [#370]
Return to the beast! :)
Not sure I understand all nodes of this section !
Section ArraysEXT
FlipNumArray Node
English
http://moiscript.weebly.com/arraysext.html#flipnumarray
11 Nov 2019   [#371]
Section ArraysExt
ArraySort Node
English
http://moiscript.weebly.com/arraysext.html#arraysort
11 Nov 2019   [#372]
Losted in arrays' fields :)
Wanted use the Z height of a cylinder
I supposed that array (1) for the Cylinder, Z will be 3 but...
I must miss something conceptual and / or Synthaxic because result don't give something!
12 Nov 2019   [#373]
A sort of sampling ? And what is the difference with Remap ?
It's "Out" against "Interp" but that gives exactly the same result !
Section ArraysExt
Remap2 Node
English
http://moiscript.weebly.com/arraysext.html#remap2
12 Nov 2019   [#374]
Does someone can just show me the different functions of Arrays not yet shown?
(very concise will be sufficient) because I am in the dark! :)
25 Nov 2019   [#375]
Thx to Karsten for enlight me on this new one :) Some others in waiting holes! :)
See http://moiscript.weebly.com/biblio-elephant.html for see the missing holes!
Section ArraysEXT
BundleArray
English
http://moiscript.weebly.com/arraysext.html#bundlearray
26 Nov 2019   [#376]
Section Curves2
Spiral Node
English
http://moiscript.weebly.com/curves2.html#spiral
26 Nov 2019   [#377] In reply to [#376]
Negative numbers on Turns will reverse spiral direction.
Wayne
26 Nov 2019   [#378] In reply to [#377]
Modified! :
If you have any lights about my not repositored nodes shown don't hesitate!
Because names of them is not sufficient for explain what they do for me! :(
8 Dec 2019   [#379]
Section Point2
GetCrvSFrame Node
Will be in English :)
http://moiscript.weebly.com/point2.html#getcrvsframe
14 Jan 2020   [#380]
Happy new year and come back! :)
A little rusted! :D Links will arrive as soon as possible! ;)
Section Object2
Clone4 Node by Brian
English
http://moiscript.weebly.com/objects2.html#clone4
21 Jan 2020   [#381]
Final Links will be made in some times...
General Repository French / English http://moiscript.weebly.com/biblio-elephant.html
Voronoï Node (By Wayne)
English
http://moiscript.weebly.com/objects2.html#voronoi
23 Jan 2020   [#382]
Perlin Node BY Wayne
Extentions / Object2
English
http://moiscript.weebly.com/objects2.html#perlinnoise
23 Jan 2020   [#383]
ImgSampler by Wayne
English
http://moiscript.weebly.com/objects2.html#imgsampler
