 276-295
 296-315
 316-335
 336-355
 356-375
 376-395
 396-415
 496-503
Section Infos
BoundingBox Infos
English
http://moiscript.weebly.com/infos.html#boundingboxinfos
It appears that the camera is moving, not the target.
The camera can move in many directions, not just revolving around the target.
Edit, As per Pilou, the target can also move:-)
Typo: Save is On or Off, not Own.
Some clarification of how to make an mpeg or avi would be nice.
Frame I understand to be one picture, in camera language, rather than MoI frame, although maybe they are interrelated?
Why not ? You must just drawing something moving...
Touche'
Sections Infos
Curvature Node
English
http://moiscript.weebly.com/infos.html#curvature
Section Infos
ShowFrame
English
http://moiscript.weebly.com/infos.html#showframe
Section Infos
BoundingBoxes Node
English
http://moiscript.weebly.com/infos.html#boundingboxes
Another time need to truncate the result! :)
Maths node has not this function and i don't see how enter inside Maths node another thing than the presets! :(
As soon as I enter another thing it's remplaced by a preset!
PS What is "STL" it's for Print 3D or it's another thing ?
Section Infos
StlVolume
http://moiscript.weebly.com/infos.html#stlvolume
From 2015, Dinos/Max Calculate volume from Stereolithograpy polygon triangles:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7421.13
https://stackoverflow.com/questions/6518404/how-do-i-calculate-the-volume-of-an-object-stored-in-stl-files
Karsten 2017 Infonodes:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.279
Javascript has truncation functions.  Maybe place a math node between Volume and Text, and use one of the Javascript truncate or round functions?
There is .toFixed(2)...StackOverflow has brief code to fix up .toFixed...
rounded_number = Math.round(number * 100) / 100  (from Geeks for Geeks)
To truncate an objectlist, I think there must be another node to do the truncation.  An array type of node...?
Maybe Stream2Array?  There is a "max" input...
I will exam all that...but i wish only nodes..not want to explore the code ;)
<<  Maybe place a math node between Volume and Text
Yes how put materially another thing than the existing presets ???
Stream2Array? There is a "max" input ...what is the use of this Array ?
else
Section Infos
StlAera Node
English
http://moiscript.weebly.com/infos.html#stlaera
I suppose that is the same Camera to use than Camera2 Node
(go there for node to load and see animation! )
http://moiscript.weebly.com/r2d3.html#camera2
Section Infos
Camera Node
English
http://moiscript.weebly.com/infos.html#camera
Section Import
CSV File Node
http://moiscript.weebly.com/import.html#csvfile
Don't know that exists an Importer STL to Moi!!!
Section Import
STL Import Node
http://moiscript.weebly.com/import.html#stlimport
Section Objects2
TrimObject
English
http://moiscript.weebly.com/objects2.html#trimobj
Section Objects2
ExtractEdges Node
English
http://moiscript.weebly.com/objects2.html#extractedges
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-extract-edges_orig.gif
Section Objects2
ExtractPts Node
English
http://moiscript.weebly.com/objects2.html#extractpts
Section Objects2
SetStyle Node
English
http://moiscript.weebly.com/objects2.html#setstyle
Section Objects2
RandomObj Node
English
http://moiscript.weebly.com/objects2.html#randomobj
Not sure of the function of the "Pinky Point" of this Node!
Was an headache to use! :)
Section Objects2
ScaleUVW Node
English
http://moiscript.weebly.com/objects2.html#scaleuvw
Regarding the point input to ScaleUVW:
For example, with your .nod file:
Place a physical MoI point at say (-5, -5, 0 ), for a reference marker.
Wire a point node, set to ( -5, -5, 0 ), to the pink input to ScaleUVW.
Place a circle at the origin, Top View, say radius 0.5.
Have slider vary from 0 to 10.
Select the circle, and Update Selected node.
Run the node.
Vary the slider.
Slider at zero places the circle at ( -5,-5, 0 ) with radius of zero.
Slider set to 1 leaves the circle at the origin, with radius 0.5.
Slider at 2 places the circle at ( 5, 5, 0 ) with radius of 1.
Slider at 3 places the circle at ( 10, 10, 0 ) with radius of 1.5.
etc.
 276-295
 296-315
 316-335
 336-355
 356-375
 376-395
 396-415
 496-503
