Show messages:  1-3  …  264-283  284-303  304-323  324-343  344-363  364-383  384-403  …
15 Oct 2019   [#324]
Something i don't find : how import from a file some words directly for this sort of node ?
Not a big deal because i can make a copy past but...
Section r2d3
Text2 Node
English
http://moiscript.weebly.com/r2d3.html#text2
With the free TwinMotion
15 Oct 2019   [#325]
Just a thought.
Can there be a node which shows or creates dimensions?
Are there methods in MoI to access the dimensions?
15 Oct 2019   [#326] In reply to [#325]
Hi Brian, yes dimensions can be created by a script.
There are 8 new factories for that: dimhorizontal, dimvertical, dimaligned, dimradius, dimangle, leader, annotationtext, arrow3d.
dimhorizontal, dimvertical, and dimaligned all create a linear dimension object, and they all have 3 inputs:
0: Frame - base plane for dimension with origin at first point
1: Point - end point
2: Point - location point
dimradius has 4 inputs:
0: Object - arc or circle curve
1: String - type of radial dimension, either "Radius" or "Diameter"
2: Point - arrow point on curve
3: Point - text point
dimangle has 4 inputs:
0: Frame - center of angle
1: Point - start point
2: Point - end point
3: Point - location point
leader has 2 fixed inputs:
0: Frame - plane with origin at arrow point
1: String - text
2+ : Point inputs added
annotationtext:
0: Base frame
1: Text
arrow3d - creates a leader with 2 points with the "rotate arrow towards viewer" property set on it, this is for James to use in the node editor for a vector direction display. It automatically creates a plane for the leader given 2 points.
0: start point
1: end point
Here's an example using arrow3d:
	var startpt = moi.vectorMath.createPoint(5,5,5);
	var endpt = moi.vectorMath.createPoint(10,10,10);
	var f = moi.command.createFactory( 'arrow3d' );
	f.setInput( 0, startpt );
	f.setInput( 1, endpt );
	var arrow = f.calculate().item(0);
	moi.geometryDatabase.addObject( arrow );
	f.cancel();
16 Oct 2019   [#327] In reply to [#326]
Thank you Michael.
16 Oct 2019   [#328]
So new nodes in perspective! :)
16 Oct 2019   [#329]
Section r2d3
Quartz2 Node
English
http://moiscript.weebly.com/r2d3.html#quartz2
16 Oct 2019   [#330]
Section r2d3
ObjToArray2
Difference than native ObjToArray is "StartEnd" but i don't know what is it! :)
Thanks to show me an example!
16 Oct 2019   [#331]
Section r2d3
Camera2 Node
What is effect of Idx ? Encoder ? Effect of save (i suppose save to file ?) and how to enable it ? (press something ?)
16 Oct 2019   [#332] In reply to [#331]
Hi Pilou.
I did a little testing with r2d3's camera1.nod. https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.861
With Frames set to, for example, 100
Frames is the number of camera pictures as test1.png, test2.png, ... test100.png, which can be snapped (picture taken).
(So maybe set Frames to say 10, for testing purposes.)
Idx is the actual number of pictures which are in the process of being taken during a Run.
I used a USB stick for the File Path entry: H:\
I placed an Ascher diamond at the origin, in Top View, for a Target.
So now, with Idx set to 0, turn Save to ON, and press Run.
100 png pictures will be taken of the Ascher diamond as it rotates, and placed in 100 png files in the H:\ directory.
(Not a very exciting set of pictures:-)
The Idx count of pictures taken increases up to 100.
Then I guess some other software can be used to make a movie from the png's
ps Setting File Path entry to: H:\Ascher will create the png's with Aschertest1.png, Aschertest2.png,... , in the H:\ directory.
Setting File Path entry to: H:\Ascher\ with the ending backslash, will use the subdirectory Ascher for the saved files test1.png, test2.png, etc.
(The subdirectory Ascher must be manually created under H:\ before using it as the File Path entry.)
Encoder or Enc, seems to be set to .png by default, although there is also .avi in the next line of code. .avi does not seem to be used. ???
I do not know how or if Camera2 can make a video. Maybe someone else can decipher the camera2 video code?
The old Camera code mentions ffmpeg. Also jones. Maybe some other software is needed?
To re-run the camera with save, reset the Idx value to 0.
17 Oct 2019   [#333] In reply to [#332]
Thx i will examine that!
17 Oct 2019   [#334]
In fact there was a ready macro by d2r3
So...
Section d2r3
Camera2 Node
English
http://moiscript.weebly.com/r2d3.html#camera2
17 Oct 2019   [#335]
Should have a number of decimal!!! :)
Section Infos
Curve Length Node
English
http://moiscript.weebly.com/infos.html#curvelength
17 Oct 2019   [#336] In reply to [#335]
Section Infos
BoundingBox Infos
English
http://moiscript.weebly.com/infos.html#boundingboxinfos
17 Oct 2019   [#337] In reply to [#334]
It appears that the camera is moving, not the target.
The camera can move in many directions, not just revolving around the target.
Edit, As per Pilou, the target can also move:-)
Typo: Save is On or Off, not Own.
Some clarification of how to make an mpeg or avi would be nice.
Frame I understand to be one picture, in camera language, rather than MoI frame, although maybe they are interrelated?
17 Oct 2019   [#338] In reply to [#337]
Why not ? You must just drawing something moving...
17 Oct 2019   [#339] In reply to [#338]
Touche'
17 Oct 2019   [#340]
Sections Infos
Curvature Node
English
http://moiscript.weebly.com/infos.html#curvature
17 Oct 2019   [#341]
Section Infos
ShowFrame
English
http://moiscript.weebly.com/infos.html#showframe
17 Oct 2019   [#342]
Section Infos
BoundingBoxes Node
English
http://moiscript.weebly.com/infos.html#boundingboxes
17 Oct 2019   [#343]
Another time need to truncate the result! :)
Maths node has not this function and i don't see how enter inside Maths node another thing than the presets! :(
As soon as I enter another thing it's remplaced by a preset!
PS What is "STL" it's for Print 3D or it's another thing ?
Section Infos
StlVolume
http://moiscript.weebly.com/infos.html#stlvolume
