 256-275
 276-295
 296-315
 316-335
 336-355
 356-375
 376-395
 496-503
Section SubD
Join Node
English
http://moiscript.weebly.com/subd2.html#join
Join several Curves in only One!
At the end run this ShortCut for have directly normal selection because it's not enabled at the end of the Nodes!
script: var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true ); }
Section SubD
The Simple Bridge is not so simple!
Accept not faces but surfaces ??? and i am sucked again with this simplicity! :)
Normally that must make that I suppose...
but...
Section SubD
Same problem for Connection Node... :(
Section SubD
SelCenterPlane
English
http://moiscript.weebly.com/subd2.html#selcenterplane
Section SubD
SubD node
English
http://moiscript.weebly.com/subd2.html#subd
Display texts + Values resolved with another headaches !:)
Was not so evident!
And now i must find something more elaborated for the mirror! A new fight with the Frame in perspective :)
For the moment it's only one orientation refexion so a little lite! :)
And as I took symmetric objects mirror is not remarquable! <:0)
so here a more understandable!
Section Transform2
Mirror Node English
http://moiscript.weebly.com/transform2.html#mirror
Section Transform2
StereoProject Node
English
http://moiscript.weebly.com/transform2.html#stereoproject
Not hyper ergonomic ...i am discovering all that ...but... :)
Mirror Node again
Something i don't find : how import from a file some words directly for this sort of node ?
Not a big deal because i can make a copy past but...
Section r2d3
Text2 Node
English
http://moiscript.weebly.com/r2d3.html#text2
With the free TwinMotion
Just a thought.
Can there be a node which shows or creates dimensions?
Are there methods in MoI to access the dimensions?
Hi Brian, yes dimensions can be created by a script.
There are 8 new factories for that: dimhorizontal, dimvertical, dimaligned, dimradius, dimangle, leader, annotationtext, arrow3d.
dimhorizontal, dimvertical,  and dimaligned all create a linear dimension object, and they all have 3 inputs:
0: Frame - base plane for dimension with origin at first point
1: Point - end point
2: Point - location point
dimradius has 4 inputs:
0: Object - arc or circle curve
1: String - type of radial dimension, either "Radius" or "Diameter"
2: Point - arrow point on curve
3: Point - text point
dimangle  has 4 inputs:
0: Frame - center of angle
1: Point - start point
2: Point -  end point
3: Point - location point
leader has 2 fixed inputs:
0: Frame - plane with origin at arrow point
1: String - text
2+ : Point inputs added
annotationtext:
0: Base frame
1: Text
arrow3d - creates a leader with 2 points with the "rotate arrow towards viewer" property set on it, this is for James to use in the node editor for a vector direction display. It automatically creates a plane for the leader given 2 points.
0: start point
1: end point
Here's an example using arrow3d:
	var startpt = moi.vectorMath.createPoint(5,5,5);
	var endpt = moi.vectorMath.createPoint(10,10,10);
	var f = moi.command.createFactory( 'arrow3d' );
	f.setInput( 0, startpt );
	f.setInput( 1, endpt );
	var arrow = f.calculate().item(0);
	moi.geometryDatabase.addObject( arrow );
	f.cancel();
Thank you Michael.
So new nodes in perspective! :)
Section r2d3
Quartz2 Node
English
http://moiscript.weebly.com/r2d3.html#quartz2
Section r2d3
ObjToArray2
Difference than native ObjToArray is "StartEnd" but i don't know what is it!  :)
Thanks to show me an example!
Section r2d3
Camera2 Node
What is effect of Idx ? Encoder ? Effect of save (i suppose save to file ?) and how to enable it ? (press something ?)
Hi Pilou.
I did a little testing with r2d3's camera1.nod.
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.861
With Frames set to, for example, 100
Frames is the number of camera pictures as test1.png, test2.png, ... test100.png, which can be snapped (picture taken).
(So maybe set Frames to say 10, for testing purposes.)
Idx is the actual number of pictures which are in the process of being taken during a Run.
I used a USB stick for the File Path entry: H:\
I placed an Ascher diamond at the origin, in Top View, for a Target.
So now, with Idx set to 0, turn Save to ON, and press Run.
100 png pictures will be taken of the Ascher diamond as it rotates, and placed in 100 png files in the H:\ directory.
(Not a very exciting set of pictures:-)
The Idx count of pictures taken increases up to 100.
Then I guess some other software can be used to make a movie from the png's
ps  Setting File Path entry to: H:\Ascher will create the png's with Aschertest1.png, Aschertest2.png,...   , in the H:\ directory.
Setting File Path entry to: H:\Ascher\  with the ending backslash, will use the subdirectory Ascher for the saved files test1.png, test2.png, etc.
(The subdirectory Ascher must be manually created under H:\ before using it as the File Path entry.)
Encoder or Enc, seems to be set to .png by default, although there is also .avi in the next line of code.  .avi does not seem to be used.  ???
I do not know how or if Camera2 can make a video.  Maybe someone else can decipher the camera2 video code?
The old Camera code mentions ffmpeg.  Also jones.  Maybe some other software is needed?
To re-run the camera with save, reset the Idx value to 0.
Thx i will examine that!
In fact there was a ready macro by d2r3
So...
Section d2r3
Camera2 Node
English
http://moiscript.weebly.com/r2d3.html#camera2
Should have a number of decimal!!! :)
Section Infos
Curve Length Node
English
http://moiscript.weebly.com/infos.html#curvelength
 256-275
 276-295
 296-315
 316-335
 336-355
 356-375
 376-395
 496-503
