Show messages:  1-10  …  251-270  271-290  291-310  311-330  331-350  351-370  371-390  …  491-503
11 Oct 2019   [#311]
Section SubD
PolyLoft Node
English
http://moiscript.weebly.com/subd2.html#polyloft
12 Oct 2019   [#312]
Section SubD
ConvertCurveToPoly
English
http://moiscript.weebly.com/subd2.html#convertcurvetopoly
12 Oct 2019   [#313]
I have some perplexity about Import/ STLImport Node !
What put between it and the OuPut ? Direct link don't work! :(
12 Oct 2019   [#314] In reply to [#313]
Hello Pilou,
stl-import works only with ASCII stl-files.
Sometimes there are some other problems also.
Please check it.
Have a nice weekend
Karsten
12 Oct 2019   [#315] In reply to [#314]
I will study that :)
12 Oct 2019   [#316]
Section SubD
Join Node
English
http://moiscript.weebly.com/subd2.html#join
Join several Curves in only One!
At the end run this ShortCut for have directly normal selection because it's not enabled at the end of the Nodes!
script: var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true ); }
12 Oct 2019   [#317]
Section SubD
The Simple Bridge is not so simple!
Accept not faces but surfaces ??? and i am sucked again with this simplicity! :)
Normally that must make that I suppose...
but...
12 Oct 2019   [#318] In reply to [#317]
Section SubD
Same problem for Connection Node... :(
12 Oct 2019   [#319]
Section SubD
SelCenterPlane
English
http://moiscript.weebly.com/subd2.html#selcenterplane
12 Oct 2019   [#320]
Section SubD
SubD node
English
http://moiscript.weebly.com/subd2.html#subd
13 Oct 2019   [#321]
Display texts + Values resolved with another headaches !:)
Was not so evident!
And now i must find something more elaborated for the mirror! A new fight with the Frame in perspective :)
For the moment it's only one orientation refexion so a little lite! :)
And as I took symmetric objects mirror is not remarquable! <:0)
so here a more understandable!
Section Transform2
Mirror Node English
http://moiscript.weebly.com/transform2.html#mirror
13 Oct 2019   [#322]
Section Transform2
StereoProject Node
English
http://moiscript.weebly.com/transform2.html#stereoproject
14 Oct 2019   [#323]
Not hyper ergonomic ...i am discovering all that ...but... :)
Mirror Node again
15 Oct 2019   [#324]
Something i don't find : how import from a file some words directly for this sort of node ?
Not a big deal because i can make a copy past but...
Section r2d3
Text2 Node
English
http://moiscript.weebly.com/r2d3.html#text2
With the free TwinMotion
15 Oct 2019   [#325]
Just a thought.
Can there be a node which shows or creates dimensions?
Are there methods in MoI to access the dimensions?
15 Oct 2019   [#326] In reply to [#325]
Hi Brian, yes dimensions can be created by a script.
There are 8 new factories for that: dimhorizontal, dimvertical, dimaligned, dimradius, dimangle, leader, annotationtext, arrow3d.
dimhorizontal, dimvertical, and dimaligned all create a linear dimension object, and they all have 3 inputs:
0: Frame - base plane for dimension with origin at first point
1: Point - end point
2: Point - location point
dimradius has 4 inputs:
0: Object - arc or circle curve
1: String - type of radial dimension, either "Radius" or "Diameter"
2: Point - arrow point on curve
3: Point - text point
dimangle has 4 inputs:
0: Frame - center of angle
1: Point - start point
2: Point - end point
3: Point - location point
leader has 2 fixed inputs:
0: Frame - plane with origin at arrow point
1: String - text
2+ : Point inputs added
annotationtext:
0: Base frame
1: Text
arrow3d - creates a leader with 2 points with the "rotate arrow towards viewer" property set on it, this is for James to use in the node editor for a vector direction display. It automatically creates a plane for the leader given 2 points.
0: start point
1: end point
Here's an example using arrow3d:
	var startpt = moi.vectorMath.createPoint(5,5,5);
	var endpt = moi.vectorMath.createPoint(10,10,10);
	var f = moi.command.createFactory( 'arrow3d' );
	f.setInput( 0, startpt );
	f.setInput( 1, endpt );
	var arrow = f.calculate().item(0);
	moi.geometryDatabase.addObject( arrow );
	f.cancel();
16 Oct 2019   [#327] In reply to [#326]
Thank you Michael.
16 Oct 2019   [#328]
So new nodes in perspective! :)
16 Oct 2019   [#329]
Section r2d3
Quartz2 Node
English
http://moiscript.weebly.com/r2d3.html#quartz2
16 Oct 2019   [#330]
Section r2d3
ObjToArray2
Difference than native ObjToArray is "StartEnd" but i don't know what is it! :)
Thanks to show me an example!
