Show messages:  1-2  …  243-262  263-282  283-302  303-322  323-342  343-362  363-382  …  503
9 Oct 2019   [#303]
Section Curves2
CurveBlend Fillet Node
English
http://moiscript.weebly.com/curves2.html#curveblend
9 Oct 2019   [#304]
Section Curves2
RebuildCurve Node
English
http://moiscript.weebly.com/curves2.html#reconstructcurve
9 Oct 2019   [#305]
Section Curves2
RebuildCurve Node
English
http://moiscript.weebly.com/curves2.html#rebuildcurve
9 Oct 2019   [#306]
Section Curves2
Flip Node
English
http://moiscript.weebly.com/curves2.html#flipcurve can maybe more smaller :)
9 Oct 2019   [#307]
Section Curves2
Extend Node
English
http://moiscript.weebly.com/curves2.html#extend
9 Oct 2019   [#308]
Section Curves2
UnwrapCurve Node
English
http://moiscript.weebly.com/curves2.html#unwrapcurve
10 Oct 2019   [#309]
Section r2d3
Selectededges Node
English
http://moiscript.weebly.com/r2d3.html#selectededges
10 Oct 2019   [#310]
Section r2d3
Fillet2 Node
English
http://moiscript.weebly.com/r2d3.html#fillet2
11 Oct 2019   [#311]
Section SubD
PolyLoft Node
English
http://moiscript.weebly.com/subd2.html#polyloft
12 Oct 2019   [#312]
Section SubD
ConvertCurveToPoly
English
http://moiscript.weebly.com/subd2.html#convertcurvetopoly
12 Oct 2019   [#313]
I have some perplexity about Import/ STLImport Node !
What put between it and the OuPut ? Direct link don't work! :(
12 Oct 2019   [#314] In reply to [#313]
Hello Pilou,
stl-import works only with ASCII stl-files.
Sometimes there are some other problems also.
Please check it.
Have a nice weekend
Karsten
12 Oct 2019   [#315] In reply to [#314]
I will study that :)
12 Oct 2019   [#316]
Section SubD
Join Node
English
http://moiscript.weebly.com/subd2.html#join
Join several Curves in only One!
At the end run this ShortCut for have directly normal selection because it's not enabled at the end of the Nodes!
script: var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true ); }
12 Oct 2019   [#317]
Section SubD
The Simple Bridge is not so simple!
Accept not faces but surfaces ??? and i am sucked again with this simplicity! :)
Normally that must make that I suppose...
but...
12 Oct 2019   [#318] In reply to [#317]
Section SubD
Same problem for Connection Node... :(
12 Oct 2019   [#319]
Section SubD
SelCenterPlane
English
http://moiscript.weebly.com/subd2.html#selcenterplane
12 Oct 2019   [#320]
Section SubD
SubD node
English
http://moiscript.weebly.com/subd2.html#subd
13 Oct 2019   [#321]
Display texts + Values resolved with another headaches !:)
Was not so evident!
And now i must find something more elaborated for the mirror! A new fight with the Frame in perspective :)
For the moment it's only one orientation refexion so a little lite! :)
And as I took symmetric objects mirror is not remarquable! <:0)
so here a more understandable!
Section Transform2
Mirror Node English
http://moiscript.weebly.com/transform2.html#mirror
13 Oct 2019   [#322]
Section Transform2
StereoProject Node
English
http://moiscript.weebly.com/transform2.html#stereoproject
