Show messages:  1-14  …  235-254  255-274  275-294  295-314  315-334  335-354  355-374  …  495-503
7 Oct 2019   [#295]
Here the Rotation Point must be an another axe! ;)
ProjectMp Node
English
http://moiscript.weebly.com/construct2.html#projectmp
8 Oct 2019   [#296] In reply to [#295]
Hello Pilou,
here is an example for using the vectors to create Frames with the vectors. Hopefully the Version I used is up to date.
Have a nice day
Karsten
ProjectMP.nod
8 Oct 2019   [#297] In reply to [#296]
I understand my error : i had read Line2Vec like "Line to Vectors" so completly missed the "FrameByVecs" !!!
So believed that only one line was sufficient...
I must past this on my screen computer! :)
And will added of course in no time here! :) http://moiscript.weebly.com/construct2.html#projectmp
8 Oct 2019   [#298] In reply to [#297]
A Macro CreateFrame could be useful?
8 Oct 2019   [#299] In reply to [#298]
Hi Karsten,
I am getting an assert failure when doing "apply". After Ignore All, the two vectors cannot be deleted from MoI.
Perhaps unrelated, closing MoI with large nodeeditor canvas, and reopening MoI4beta and nodeeditor results in a large canvas with white top area hidden, and the canvas cannot be moved, unless the canvas is side dragged to be skinnier. (Cannot reproduce this effect...)
I'm trying to understand the frames.
Max incorporated Frames into the PointArray datatype. There is an old post that he made about this accomplishment.
Regarding FrameByVecs:
Adding ConvertPts and Output to the point output of FrameByVecs shows that its output Frame is located as a point at the common beginning point of the two vector inputs,
xdir and ydir.
xdir input establishes the x direction of the output frame. The ydir input does not have to be in the y direction of MoI.
Orthogonality to xdir doesn't seem to matter, as long as ydir has a nonzero value for y or z arrow point of the second input vector.
Karsten's example node uses z = 5 for the ydir vector, but y = 5 would also work, as well as other combinations of z and y.
The axis labels are still not showing up in MoI4 beta.
The addition of 3 outputs to the three vector definition points shows the 3 points to be at the three arrow tips of the 3 Line2Vec nodes.
-Brian
8 Oct 2019   [#300]
Section Curves2
Helix Node
English
http://moiscript.weebly.com/curves2.html#helix
8 Oct 2019   [#301]
@ karsten : i have resolved my headache! :)
So simple! :)
8 Oct 2019   [#302]
Section Curves2
CurveFillet Node
English
http://moiscript.weebly.com/curves2.html#curvefillet
9 Oct 2019   [#303]
Section Curves2
CurveBlend Fillet Node
English
http://moiscript.weebly.com/curves2.html#curveblend
9 Oct 2019   [#304]
Section Curves2
RebuildCurve Node
English
http://moiscript.weebly.com/curves2.html#reconstructcurve
9 Oct 2019   [#305]
Section Curves2
RebuildCurve Node
English
http://moiscript.weebly.com/curves2.html#rebuildcurve
9 Oct 2019   [#306]
Section Curves2
Flip Node
English
http://moiscript.weebly.com/curves2.html#flipcurve can maybe more smaller :)
9 Oct 2019   [#307]
Section Curves2
Extend Node
English
http://moiscript.weebly.com/curves2.html#extend
9 Oct 2019   [#308]
Section Curves2
UnwrapCurve Node
English
http://moiscript.weebly.com/curves2.html#unwrapcurve
10 Oct 2019   [#309]
Section r2d3
Selectededges Node
English
http://moiscript.weebly.com/r2d3.html#selectededges
10 Oct 2019   [#310]
Section r2d3
Fillet2 Node
English
http://moiscript.weebly.com/r2d3.html#fillet2
11 Oct 2019   [#311]
Section SubD
PolyLoft Node
English
http://moiscript.weebly.com/subd2.html#polyloft
12 Oct 2019   [#312]
Section SubD
ConvertCurveToPoly
English
http://moiscript.weebly.com/subd2.html#convertcurvetopoly
12 Oct 2019   [#313]
I have some perplexity about Import/ STLImport Node !
What put between it and the OuPut ? Direct link don't work! :(
12 Oct 2019   [#314] In reply to [#313]
Hello Pilou,
stl-import works only with ASCII stl-files.
Sometimes there are some other problems also.
Please check it.
Have a nice weekend
Karsten
