 217-236
 237-256
 257-276
 277-296
 297-316
 317-336
 337-356
 497-503
I am perplex : i don't find the trick for input the right thing inside the Frame!
How do you  process?
this Selected --ObjtoArray --Frame like following don't work! :(
Shell node
English
http://moiscript.weebly.com/construct2.html#shell
If you have a volume must be separated for surfaces wanted!
Seems BrepNameSubOject necessary
Flip or Center line...(for volume)
Line Web Node
English
http://moiscript.weebly.com/construct2.html#lineweb
Fillet2 Node
English
http://moiscript.weebly.com/construct2.html#fillet2
Global Fillet on volume(s)
Ok i haved finished the Section Not Native Construct2 all English ;) Next will be Curve2
...except these 2 little things where i am sucked! :(
if you have some ideas ?
For Frame, try vector\FrameByVec.
Right hand rule with two orthogonal vectors yields z axis.
I find a lot of the point characteristics confusing:-)
Lots of luck with SplitPts and PointExt.
There are also Infos/ShowFrame
and Points2/getCrvSFrame
Text2:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.936
Thx i will test all that!
About the Text2 that works fine for "number" but that I want is add a Text say a paragraph from any source.
I know that I can input it in the case box of the node itself...but want input from a file ...
Ps about the files from r2d3  i can't have the "concat2" who stay red ! (even loaded the r2d3 .js in extension folder )
else loaded the waves by r2d3 ;)
About vectors not better...but it's my lack of use and what is a vector inside Elephant! :)
This really draw only the "red ARROW"!  Pity because that was cool for draw a vector! :)
I always don't know what the "Frame" is really wanted!
( seems I have a line selected in the good direction)
Not better with that! :) Mystery always!
(i run it of course... this image if before the new run ...line is not yet selected)
Hello Pilou,
you can't define a plane/Frame with identical/colinear vectors. X-direction and y-direction have to be different by Default;-)
Have a nice day
Karsten
<< X-direction and y-direction have to be different by Default;-)
I miss the principal trick! :)
But what is indicated the direction toward the sphere ?
Here i want the "Y" ...this frame is an headache for me for the moment! :)
Orient node can be helping ?
Hello Pilou,
first: Points in the nodeeditor are also Frames. A Frame has an origin that is also a Point. In Your example X-Axis is the x-Axis. Now define a line in the shown z-Axis as your y-Axis Input. The resulting z-Axis is like your y-Axis - only in the wrong direction - but that doesn't matters I think.
That's Basic vector math. The z-vector is the cross product of the x and y vector.
Have a nice day
Karsten
I will meditate that! :!
That's not the technic who affraid me it's the application with nodes! :)
some many tests with this node
no success :(
Size of the red cone is according to the size's line! :)
But always not valide for my Projection by Direction! :(
To set the direction in projectMP, use rotatePts like so.
(image a bit blurred in compression: rY value = 90)
Hope this helps
Many thx! So cool the result seems effective!
And seems an only one Point is sufficient as "Frame" if i good understand! :)
Maybe in the futur when i will be more experimented all that will be more automatic!
And maybe find a mnemotechnic trick for have this good point following the position to manage!
Now rest the ultima thing for the text2 : can we input text (not "number")(from a file maybe cvs(?) in the text input circle button?
Here the Rotation Point must be an another axe! ;)
ProjectMp Node
English
http://moiscript.weebly.com/construct2.html#projectmp
Hello Pilou,
here is an example for using the vectors to create Frames with the vectors. Hopefully the Version I used is up to date.
Have a nice day
Karsten
ProjectMP.nod
 217-236
 237-256
 257-276
 277-296
 297-316
 317-336
 337-356
 497-503
