Show messages:  1-10  …  211-230  231-250  251-270  271-290  291-310  311-330  331-350  …  491-503
5 Oct 2019   [#271]
Text has no difficulties! :)
Text Node
English
http://moiscript.weebly.com/construct2.html#text
5 Oct 2019   [#272]
Numbering Node
English http://moiscript.weebly.com/construct2.html#numbering
5 Oct 2019   [#273]
You can now have directly access to each No Native Node itself from the forum! :)
see previous posts https://moi3d.com/forum/index.php?webtag=MOI&msg=9476.247 or futur following ;)
or All not native ;) http://moiscript.weebly.com/all-nodes.html#allnodenonative
PS direct access from a section istself will be made when a section will be finished!
Edit direct access is done! http://moiscript.weebly.com/biblio-elephant.html#allnodenonative
5 Oct 2019   [#274]
RailRevolve Node
English
http://moiscript.weebly.com/construct2.html#railrevolve
6 Oct 2019   [#275]
A more classic example of RailRevolve! ;)
I take a Point as center of Axe : seems vertical by default!
Wished a simple method for input a "frame" inclined!
6 Oct 2019   [#276]
Network Node
English
http://moiscript.weebly.com/construct2.html#network
6 Oct 2019   [#277]
I am perplex : i don't find the trick for input the right thing inside the Frame!
How do you process?
this Selected --ObjtoArray --Frame like following don't work! :(
6 Oct 2019   [#278]
Shell node
English
http://moiscript.weebly.com/construct2.html#shell
If you have a volume must be separated for surfaces wanted!
Seems BrepNameSubOject necessary
Flip or Center line...(for volume)
6 Oct 2019   [#279]
Line Web Node
English
http://moiscript.weebly.com/construct2.html#lineweb
6 Oct 2019   [#280]
Fillet2 Node
English
http://moiscript.weebly.com/construct2.html#fillet2
Global Fillet on volume(s)
6 Oct 2019   [#281]
Ok i haved finished the Section Not Native Construct2 all English ;) Next will be Curve2
...except these 2 little things where i am sucked! :(
if you have some ideas ?
7 Oct 2019   [#282] In reply to [#281]
For Frame, try vector\FrameByVec.
Right hand rule with two orthogonal vectors yields z axis.
I find a lot of the point characteristics confusing:-)
Lots of luck with SplitPts and PointExt.
There are also Infos/ShowFrame
and Points2/getCrvSFrame
Text2:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.936
7 Oct 2019   [#283] In reply to [#282]
Thx i will test all that!
About the Text2 that works fine for "number" but that I want is add a Text say a paragraph from any source.
I know that I can input it in the case box of the node itself...but want input from a file ...
Ps about the files from r2d3 i can't have the "concat2" who stay red ! (even loaded the r2d3 .js in extension folder )
else loaded the waves by r2d3 ;)
7 Oct 2019   [#284]
About vectors not better...but it's my lack of use and what is a vector inside Elephant! :)
7 Oct 2019   [#285]
This really draw only the "red ARROW"! Pity because that was cool for draw a vector! :)
I always don't know what the "Frame" is really wanted!
( seems I have a line selected in the good direction)
7 Oct 2019   [#286]
Not better with that! :) Mystery always!
(i run it of course... this image if before the new run ...line is not yet selected)
7 Oct 2019   [#287] In reply to [#285]
Hello Pilou,
you can't define a plane/Frame with identical/colinear vectors. X-direction and y-direction have to be different by Default;-)
Have a nice day
Karsten
7 Oct 2019   [#288] In reply to [#287]
<< X-direction and y-direction have to be different by Default;-)
I miss the principal trick! :)
But what is indicated the direction toward the sphere ?
Here i want the "Y" ...this frame is an headache for me for the moment! :)
Orient node can be helping ?
7 Oct 2019   [#289] In reply to [#288]
Hello Pilou,
first: Points in the nodeeditor are also Frames. A Frame has an origin that is also a Point. In Your example X-Axis is the x-Axis. Now define a line in the shown z-Axis as your y-Axis Input. The resulting z-Axis is like your y-Axis - only in the wrong direction - but that doesn't matters I think.
That's Basic vector math. The z-vector is the cross product of the x and y vector.
Have a nice day
Karsten
7 Oct 2019   [#290] In reply to [#289]
I will meditate that! :!
That's not the technic who affraid me it's the application with nodes! :)
