Show messages:  1  …  202-221  222-241  242-261  262-281  282-301  302-321  322-341  …  502-503
5 Oct 2019   [#262]
MLoft2 Node
English
http://moiscript.weebly.com/construct2.html#mloft2
5 Oct 2019   [#263]
Construct2/ Isocurves
Seems something is missing ? Only horizontal ...
5 Oct 2019   [#264]
Hello Pilou!
You're really doing a SUPERB job with all this docs and tutorials!!!
Hats off!
5 Oct 2019   [#265] In reply to [#264]
Thx but a long race and will be soon slowed-down because Nodes are not so evident! :)
IsoCrvs Node
English
http://moiscript.weebly.com/construct2.html#isocrvs
In fact E0..E3 are not missing but seems work only a Surface not on a volume!
You must Display the volume if you want see it in the same time than the IsoCurves!
5 Oct 2019   [#266]
Not Native Nodes By Sections ...that is some frightening! :)
English (Native and not Native)
http://moiscript.weebly.com/all-nodes.html#allnodenonative
Array Ext
Basics2
Points2
Construct2
Curves2
Import
Infos
SubD
Obj2
Transform2
Vectors
5 Oct 2019   [#267]
Notice that the nodes in construct2.js are all set up to use the Info button.
The getExtraMenuOptions code has already been inserted :D
All that is needed is to write the .html Info documentation files for each such node.
ps, How does one change to say the FR, French version?
Changing lang.js to "FR" is not sufficient.
5 Oct 2019   [#268] In reply to [#267]
<< How does one change to say the FR, French version?
It's not automatic when you enable French inside Moi's Options ?
5 Oct 2019   [#269] In reply to [#268]
Thank you Pilou. MoI is now in French for a temporary test, after using MoI Option button, language version, set to French.
I'm still unable to get a French .html documentation info window...
5 Oct 2019   [#270] In reply to [#269]
For progress in getting node Info documentation in French to work, please see
https://moi3d.com/forum/index.php?webtag=MOI&msg=9518.6
5 Oct 2019   [#271]
Text has no difficulties! :)
Text Node
English
http://moiscript.weebly.com/construct2.html#text
5 Oct 2019   [#272]
Numbering Node
English http://moiscript.weebly.com/construct2.html#numbering
5 Oct 2019   [#273]
You can now have directly access to each No Native Node itself from the forum! :)
see previous posts https://moi3d.com/forum/index.php?webtag=MOI&msg=9476.247 or futur following ;)
or All not native ;) http://moiscript.weebly.com/all-nodes.html#allnodenonative
PS direct access from a section istself will be made when a section will be finished!
Edit direct access is done! http://moiscript.weebly.com/biblio-elephant.html#allnodenonative
5 Oct 2019   [#274]
RailRevolve Node
English
http://moiscript.weebly.com/construct2.html#railrevolve
6 Oct 2019   [#275]
A more classic example of RailRevolve! ;)
I take a Point as center of Axe : seems vertical by default!
Wished a simple method for input a "frame" inclined!
6 Oct 2019   [#276]
Network Node
English
http://moiscript.weebly.com/construct2.html#network
6 Oct 2019   [#277]
I am perplex : i don't find the trick for input the right thing inside the Frame!
How do you process?
this Selected --ObjtoArray --Frame like following don't work! :(
6 Oct 2019   [#278]
Shell node
English
http://moiscript.weebly.com/construct2.html#shell
If you have a volume must be separated for surfaces wanted!
Seems BrepNameSubOject necessary
Flip or Center line...(for volume)
6 Oct 2019   [#279]
Line Web Node
English
http://moiscript.weebly.com/construct2.html#lineweb
6 Oct 2019   [#280]
Fillet2 Node
English
http://moiscript.weebly.com/construct2.html#fillet2
Global Fillet on volume(s)
6 Oct 2019   [#281]
Ok i haved finished the Section Not Native Construct2 all English ;) Next will be Curve2
...except these 2 little things where i am sucked! :(
if you have some ideas ?
