 193-212
 213-232
 233-252
 253-272
 273-292
 293-312
 313-332
 493-503
> when you return to Moi from or after use of the Node editor
> size of the File Menus of the bottom barr are reduced!!!
> And never come back normal before a close pf Node Editor!
Hmm, that's not happening to me over here. Does your file menu also appear some distance above the File button too?
Can you please post a .zip file of your node editor so I can test with your same one over here?
Thanks,  - Michael
Sure... here the file
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/nodeeditor.zip
I am on PC Latop + Monitor
<<  Does your file menu also appear some distance above the File button too?
Yes as shown on my previous image when there is a reduction!
In normal time all is "pasted" and with same size! :)
For elimate that i close the Nodeeditor and recall it...not a big deal ...just curious...
I suspect a not clean exit of some nodes! :)
Edit : in fact that is the use of the monitor!  So resolved!
As soon as i move the NodeEditor on it there is reduction of the File windows when i call it!
As soon as i move the NodeEditor on the Latop there is no reduction of the File Windows when i call it! :)
Of course that is not the case with other programs ...not a big trouble! :)
If I use Moi on the Monitor there is no reduction! (without call NodeEditor)
but a little trouble...when I call it...in some case...
Moi on the Monitor full screen...Node Editor on the Latop ...I can't see the File Windows...I must reduce the Full screen of Moi !
If the Node Editor is on the Monitor over the Full screen Moi all is fine! :)
Again not a big deal :)
Offset Node more easy :)
English
http://moiscript.weebly.com/construct2.html#offset
Mloft2 make not more than Loft 2 families of Curves ?
I have speedy seen all that : no problem except the 2 last!
Planar ok
isoCrvs ok
Text ok
Numbering​ ok
RailRevolve ok
network ok
ProjectMp ok
Shell ok
LineWeb ok
Fillet2 ?
Text2 ?
Ok for the Fillet2!
It works exactly like the Fillet above! :)
Rest the Input text!
Planar Node
 English
http://moiscript.weebly.com/construct2.html#planar
Hi Pilou
BrepnameSuObjects is useless with Fllet2
Cool so more speedy! But seems you can't select edge(s) wished so a "global fillet ? !  (and I see you use the French version! ;)
And about the Construct2/Fillet how do you manage and use the adjacent Faces ?
If before i select Face(s) against Edges i have no result...
If I select only Edges I have no result...
If I select Edges + Faces I have no result...
MLoft2 Node
English
http://moiscript.weebly.com/construct2.html#mloft2
Construct2/ Isocurves
Seems something is missing ? Only horizontal ...
Hello Pilou!
You're really doing a SUPERB job with all this docs and tutorials!!!
Hats off!
Thx but a long race and will be soon slowed-down because Nodes are not so evident! :)
IsoCrvs Node
English
http://moiscript.weebly.com/construct2.html#isocrvs
In fact E0..E3 are not missing but seems work only a Surface not on a volume!
You must Display the volume if you want see it in the same time than the IsoCurves!
Not Native Nodes By Sections ...that is some frightening! :)
English (Native and not Native)
http://moiscript.weebly.com/all-nodes.html#allnodenonative
Array Ext
Basics2
Points2
Construct2
Curves2
Import
Infos
SubD
Obj2
Transform2
Vectors
Notice that the nodes in construct2.js are all set up to use the Info button.
The getExtraMenuOptions code has already been inserted :D
All that is needed is to write the .html Info documentation files for each such node.
ps, How does one change to say the FR, French version?
Changing lang.js to "FR" is not sufficient.
<< How does one change to say the FR, French version?
It's not automatic when you enable French inside Moi's Options ?
Thank you Pilou.  MoI is now in French for a temporary test, after using MoI Option button, language version, set to French.
I'm still unable to get a French .html documentation info window...
For progress in getting node Info documentation in French to work, please see
https://moi3d.com/forum/index.php?webtag=MOI&msg=9518.6
Text has no difficulties! :)
Text Node
English
http://moiscript.weebly.com/construct2.html#text
Numbering Node
English
http://moiscript.weebly.com/construct2.html#numbering
 193-212
 213-232
 233-252
 253-272
 273-292
 293-312
 313-332
 493-503
