Show messages:  1-3  4-23  24-43  44-63  64-83  84-103  …
26 Aug 2019   [#24]
Some training for refind the logic of Nodes! Not so trivial :) (and some instability of the not native functions: see next post)
26 Aug 2019   [#25]
Have you this same error message with this little "nodes" ? (above one)
I have only 8 giga hard memory but don't know if this explain that...
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/toto.nod
26 Aug 2019   [#26] In reply to [#25]
Your node worked here, and made a "donut".
Windows 10, 16GB ram, nod works for either MoI4Beta or MoI3.
(Recent ssd reinstall, with James updates here: http://moi3d.com/forum/messages.php?webtag=MOI&msg=9358.1)
26 Aug 2019   [#27] In reply to [#25]
I get the same error message.
I'm on macOS....Are you?
26 Aug 2019   [#28] In reply to [#25]
Hi Pilou, if you push the "Report" button does it generate a crash report file? That will be a file named moi_report1.zip . If you get one of those please e-mail it to me at moi@moi3d.com and I'll take a look.
26 Aug 2019   [#29] In reply to [#28]
Michael,
When I press "Report" button the error dialog box disappears & immediately reappears but does not generate an error report. Clicking again does the same...& does so for a dozen more clicks.
If then the .nod is STOPped & RUN again (or link to OUTPUT is broken & reconnected) the error
message does not appear.
As I said before, I'm on a Mac.
26 Aug 2019   [#30] In reply to [#29]
Hi James, yes sorry the assert crash dump mechanism is not enabled for the Mac version.
27 Aug 2019   [#31]
I am on PC so maybe I will can send the Repport error! :)
27 Aug 2019   [#32]
On what folder exit must be this Repport error ? (seems it's a multiple repport )
27 Aug 2019   [#33]
Added http://moiscript.weebly.com/node.html
Tips
Use the TAB key for validate numeric imput!
More easy than the Enter Key : automatically goes to the next case!
Some colors Nodes can have several "Start" : Light Green and Violet!
​Same multiple Targets are not allowed!
PS Node Star has no word "Out" !
27 Aug 2019   [#34] In reply to [#32]
Hi Pilou, it would usually be in your temp folder, from the start menu type %temp% and push enter.
27 Aug 2019   [#35] In reply to [#34]
Alas seems the "special" report when I press it from these particular Nodes gives nothing in this temp folder !...
27 Aug 2019   [#36] In reply to [#35]
Hi Pilou, does everything go ok if you use "Ignore all" ? The next release will have these warnings (called "Release mode asserts") turned off.
27 Aug 2019   [#37] In reply to [#36]
Yes all is ok when I press "Ignore" all :) but also can totally exit from MOi without any warning! :) (but not total crashe just Moi)
I believe that rude exit happend when in these particular Nodes above for the no native node function "Fillets" has bad range for the volume considered!
27 Aug 2019   [#38]
Added
Tips
The fictitious "radius" of the Circular Array is made by difference of the position of the selected objects and the position of the requested axis! (here XYZ = 0,0,0 and XY = 2,2,0)
27 Aug 2019   [#39]
Will be added of course :)
done! :) http://moiscript.weebly.com/biblio-elephant.html
All ELEPHANT by Max Smirnov is actually based on this Litegraph ! https://github.com/jagenjo/litegraph.js by Jagenjo
We can use it "ON Line" http://tamats.com/projects/litegraph/demo/
Funny it has used an image of me for illustrate its genious tool! :)
https://github.com/jagenjo/litegraph.js/blob/master/imgs/elephant.gif
27 Aug 2019   [#40]
Added
27 Aug 2019   [#41] In reply to [#33]
Star node DOES have "out", on my computer.
This suggests that something is wrong with your nodeeditor files(?)
Maybe in your language files? sortie?
Maybe copy in a fresh copy of the curves nodes?
27 Aug 2019   [#42] In reply to [#41]
It's inside the English & French original for me!
Maybe I erased something many time ago during translation?
So I will investigate this curious thing! Not vital for the moment! :)
27 Aug 2019   [#43] In reply to [#42]
I just looked at the Word documentation pictures that I did a few months ago, and
Star DOES NOT have "Out", in those pictures.
So we both had a bad copy of Curves.js nodes back then. I have recently reinstalled, so have "Out" with Star now.
(I used Jame's files.)
