Show messages:  1-20  …  141-160  161-180  181-200  201-220  221-240  241-260  261-280  …  501-503
19 Sep 2019   [#201] In reply to [#200]
Ok will study that :)
else
Random Node (English French)
http://moiscript.weebly.com/basic.html
19 Sep 2019   [#202]
Concat Node (English French) Thanks to Karsten ;)
19 Sep 2019   [#203]
Hum hum ... am I right? So that I made above is not totally adequate! :)
The ObjtoArray don't change all the OutPut...
19 Sep 2019   [#204]
I miss another important concept! :)
19 Sep 2019   [#205] In reply to [#204]
19 Sep 2019   [#206] In reply to [#205]
... (always 2 separated curves selected)
That i find difficult is to pass from a color link to another color link...so useful is the general screen of nodes...
Not yet found the trick...i have now only one point against a complete curve(s) wanted! :)
...or more simple how to obtain Points from a curve selected ? Clone To Pts seems a good candidate but...
Ok I find "how to obtain Points from a curve selected" but it's not inside the Native Nodes! :(
...and always not that i want: result of the join of something coming from the pinky "array" here more than one point (with the native nodes)2 curves from the
or better the rescue of the 2 curves from the Concat of the pinky "array" (always with the natives nodes)
20 Sep 2019   [#207]
Extract Node (English French)
20 Sep 2019   [#208]
Does it possible to Show Hide the Grid of the NodeEditor ?
20 Sep 2019   [#209]
Interp Node ( English French)
20 Sep 2019   [#210]
The ultima Native last is the "Quartz" Node : i suppose that is a timer but i have not many ideas for use it! :)
If you have a little example ? That will be fine! :)
20 Sep 2019   [#211]
The next one "Not Native Node" will maybe a little more difficult for me! :)
I would probably need some big help from the creators!
But before to begin this monstruous part i will make some fun training with the natives ones for some relaxing! :)
20 Sep 2019   [#212] In reply to [#208]
re: Show/Hide grid of nodeeditor.
Maybe make a white on white grid version of nodeeditor based upon James's alternate color scheme.
This would appear grid-less?
Grid-less color scheme could be assigned a hotkey, and .nod program opened in it?
Could grid colors be changed in an existing/open node canvas, with some added code?
When moving nodes, the nodes have a "snap to nearest grid" feature.
20 Sep 2019   [#213] In reply to [#210]
Small example of Quartz node
20 Sep 2019   [#214] In reply to [#212]
@Bem I have believed seen somewhere that we can Show / Hide Grid but maybe i have dreamed :)
20 Sep 2019   [#215] In reply to [#213]
@WayneHill Many thanks...Bravo! I can now finish my Native Nodes Section!
Excellent! I see the potential! Perfect for animation! ;)
As you can see i didn't made many efforts! Copy Move your original Object
Changed Tic-Tac to Cycled and changed "Value" parameters! :)
20 Sep 2019   [#216]
Don't find what is this Const ??? It don't appears in the Quartz Info Pannel ???
Not a problem but... :)
20 Sep 2019   [#217]
The last of the Elephant Native Nodes!
You can find all that here ! http://moiscript.weebly.com/biblio-elephant.html In English! ;) and of course in French also! :)
I will make a little break for use them for the fun before to start the Extention Nodes section! :D
So the Quartz Node : a funny one! Thanks to Waynehill!
20 Sep 2019   [#218] In reply to [#216]
Hz is for Hertz, the frequency or cycles per second.
In other words, the speed of the clock, or the speed of the twisting.
In general terms, a frequency of 1 hertz means that something happens once a second, but in the
nodeeditor program, the speed may be faster or slower. So it is the relative speed.
Examples:
Hz = 0.1 is slow twist...
Hz = 5 for faster twist...
The frequency could be measured, but may vary depending upon computer?, software load? etc ?
20 Sep 2019   [#219] In reply to [#218]
OK ...as i seen no notable difference with little or more bigger numbers i was perplex!
Thanks for the explanation!
20 Sep 2019   [#220] In reply to [#219]
On my computer, your excellent quartz/twist node runs slow at HZ = .1, and runs
rapidly at HZ = 1 or 2...
Maybe computer speed makes a difference?
