 140-159
 160-179
 180-199
 200-219
 220-239
 240-259
 260-279
 500-503
Hello Pilou,
concat joins Arrays together. e.g.:
numarray 1: 0;2;4;6
numarray 2; 1;2;3;4
concat result 0;2;4;6;1;2;3;4
A nice day to all
Karsten
Ok will study that :)
else
Random Node (English French)
http://moiscript.weebly.com/basic.html
Concat Node (English French)  Thanks to Karsten ;)
Hum hum ... am I right? So that I made above is not totally adequate! :)
The ObjtoArray don't change all the OutPut...
I miss another important concept! :)
... (always 2 separated curves selected)
That i find difficult is to pass from a color link to another color link...so useful is the general screen of nodes...
Not yet found the trick...i have now only one point against a complete curve(s) wanted! :)
...or more simple how to obtain Points from a curve selected  ? Clone To Pts seems a good candidate but...
Ok I find "how to obtain Points from a curve selected" but it's not inside the Native Nodes! :(
...and always not that i want: result of the join of something coming from the pinky "array" here more than one point (with the native nodes)2 curves from the
or better the rescue of the 2 curves from the Concat of the pinky "array" (always with the natives nodes)
Extract Node (English French)
Does it possible to Show Hide the Grid of the NodeEditor ?
Interp Node ( English French)
The ultima Native last is the "Quartz" Node : i suppose that is a timer but i have not many ideas for use it! :)
If you have a little example ? That will be fine! :)
The next one "Not Native Node" will maybe a little more difficult for me! :)
I would probably need some big help from the creators!
But before to begin this monstruous part i will make some fun training with the natives ones for some relaxing! :)
re: Show/Hide grid of nodeeditor.
Maybe make a white on white grid version of nodeeditor based upon James's alternate color scheme.
This would appear grid-less?
Grid-less color scheme could be assigned a hotkey, and .nod program opened in it?
Could grid colors be changed in an existing/open node canvas, with some added code?
When moving nodes, the nodes have a "snap to nearest grid" feature.
Small example of Quartz node
@Bem  I have believed seen somewhere that we can Show / Hide Grid but maybe i have dreamed :)
@WayneHill Many thanks...Bravo! I can now finish my Native Nodes Section!
Excellent! I see the potential! Perfect for animation! ;)
As you can see i didn't made many efforts! Copy Move your original Object
Changed Tic-Tac to Cycled and changed "Value" parameters! :)
Don't find what is this Const ??? It don't appears in the Quartz Info Pannel ???
Not a problem but... :)
The last of the Elephant Native Nodes!
You can find all that here !
http://moiscript.weebly.com/biblio-elephant.html  In English! ;) and of course in French also! :)
I will make a little break for use them for the fun before to start the Extention Nodes section! :D
So the Quartz Node :  a funny one! Thanks to Waynehill!
Hz is for Hertz, the frequency or cycles per second.
In other words, the speed of the clock, or the speed of the twisting.
In general terms, a frequency of 1 hertz means that something happens once a second, but in the
nodeeditor program, the speed may be faster or slower.  So it is the relative speed.
Examples:
Hz = 0.1 is slow twist...
Hz = 5 for faster twist...
The frequency could be measured, but may vary depending upon computer?, software load? etc ?
OK ...as i seen no notable difference with little or more bigger numbers i was perplex!
Thanks for the explanation!
 140-159
 160-179
 180-199
 200-219
 220-239
 240-259
 260-279
 500-503
