Show messages:  1-14  …  135-154  155-174  175-194  195-214  215-234  235-254  255-274  …  495-503
18 Sep 2019   [#195] In reply to [#194]
@ karsten
Very elegant and the trick was the big conceptual paradigma "Progression Node" that I totally missed!
and Bravo only use the Native Nodes!
and less intimidating than this one!
So I can make the "Math" node now after study in depth for no deviant art! :)
18 Sep 2019   [#196]
18 Sep 2019   [#197]
Math Node (English French) Many Thanks to Karsten!
http://moiscript.weebly.com/basic.html
19 Sep 2019   [#198]
I am perplex about what exactly do Concat ? (add, associate, Union, Merge... ??? )
19 Sep 2019   [#199]
Forgotten to make ObjToArray Node
but this yet made can make the trick ! :)
ObjToArray Node (English French)
http://moiscript.weebly.com/objects.html
19 Sep 2019   [#200] In reply to [#198]
Hello Pilou,
concat joins Arrays together. e.g.:
numarray 1: 0;2;4;6
numarray 2; 1;2;3;4
concat result 0;2;4;6;1;2;3;4
A nice day to all
Karsten
19 Sep 2019   [#201] In reply to [#200]
Ok will study that :)
else
Random Node (English French)
19 Sep 2019   [#202]
Concat Node (English French) Thanks to Karsten ;)
19 Sep 2019   [#203]
Hum hum ... am I right? So that I made above is not totally adequate! :)
The ObjtoArray don't change all the OutPut...
19 Sep 2019   [#204]
I miss another important concept! :)
19 Sep 2019   [#205] In reply to [#204]
19 Sep 2019   [#206] In reply to [#205]
... (always 2 separated curves selected)
That i find difficult is to pass from a color link to another color link...so useful is the general screen of nodes...
Not yet found the trick...i have now only one point against a complete curve(s) wanted! :)
...or more simple how to obtain Points from a curve selected ? Clone To Pts seems a good candidate but...
Ok I find "how to obtain Points from a curve selected" but it's not inside the Native Nodes! :(
...and always not that i want: result of the join of something coming from the pinky "array" here more than one point (with the native nodes)2 curves from the
or better the rescue of the 2 curves from the Concat of the pinky "array" (always with the natives nodes)
20 Sep 2019   [#207]
Extract Node (English French)
20 Sep 2019   [#208]
Does it possible to Show Hide the Grid of the NodeEditor ?
20 Sep 2019   [#209]
Interp Node ( English French)
20 Sep 2019   [#210]
The ultima Native last is the "Quartz" Node : i suppose that is a timer but i have not many ideas for use it! :)
If you have a little example ? That will be fine! :)
20 Sep 2019   [#211]
The next one "Not Native Node" will maybe a little more difficult for me! :)
I would probably need some big help from the creators!
But before to begin this monstruous part i will make some fun training with the natives ones for some relaxing! :)
20 Sep 2019   [#212] In reply to [#208]
re: Show/Hide grid of nodeeditor.
Maybe make a white on white grid version of nodeeditor based upon James's alternate color scheme.
This would appear grid-less?
Grid-less color scheme could be assigned a hotkey, and .nod program opened in it?
Could grid colors be changed in an existing/open node canvas, with some added code?
When moving nodes, the nodes have a "snap to nearest grid" feature.
20 Sep 2019   [#213] In reply to [#210]
Small example of Quartz node
20 Sep 2019   [#214] In reply to [#212]
@Bem I have believed seen somewhere that we can Show / Hide Grid but maybe i have dreamed :)
