Show messages:  1-6  …  87-106  107-126  127-146  147-166  167-186  187-206  207-226  …  487-503
10 Sep 2019   [#147] In reply to [#146]
yes but seems all that is in the "extention" parts!
So stay in stand by till I finish the "native" part :)
10 Sep 2019   [#148]
Section POINTS
http://moiscript.weebly.com/points-e.html
Points Node (English French) not sure of what is this! (from where comes the first curve of points? A simple line of ... by default because I have nothing selected! :)
11 Sep 2019   [#149]
InterpPts Node (English French)
11 Sep 2019   [#150]
SpherePts Node ( English French)
11 Sep 2019   [#151]
PolygonPts Node ( English French )
11 Sep 2019   [#152]
MovePts Nodes (English French)
11 Sep 2019   [#153]
RotatePts Node (English French)
12 Sep 2019   [#154]
Added a short synthetic (i wish:) explanation of each yet made Point Node section! :) (English French)
12 Sep 2019   [#155]
I am perplex about the ScalePts Node!
Don't work as supposed! (like the previous nodes)
I believe that Points would move away but nothing more than the still start position! ???
(there is nothing drawn on the rest of the screen)
I must miss something!
2 points are selected at the start!
12 Sep 2019   [#156]
TextPts Node (English) surrely more possiblities but this is working! :)
12 Sep 2019   [#157]
Clone To Points ( English French) ...and better understand of what was the "Points" Node! (a simple variable 3D Array! :)
Input Selection inside an Array Base(s) of Points
12 Sep 2019   [#158]
I must understand how works the ScalePts! ??? Its also used inside JitterPts...
That is for the moment mysterious! (for me) :)
12 Sep 2019   [#159]
Need some infos about the Modes Step Twist Explode of TransformPTS node :)
12 Sep 2019   [#160]
ConvertPts Node ( English French) You have the weekend for give me some infos about MathsPts, ScalePts :)
Because i am in the jungle with these 2 last!
Little images of very simple nodes example if possible! Thx by advance!
13 Sep 2019   [#161]
Before Infos about MathPts & ScalePts i can start that seems the more easy : the Basic Section! :)
Const Node (English French)
http://moiscript.weebly.com/basic.html
13 Sep 2019   [#162]
OutPut Node (English French) (don't know why Style's list is in French :)
13 Sep 2019   [#163] In reply to [#155]
It does seem like ScalePts node is not working. Maybe it needs different inputs?
I suspect that the problem is that the Pink Dots represent a pointarray class, which is much more than just raw points.
Max wrote: "point/frame array", and also "One more node added - TextArray
It converts text data to pointarray. For each point can be set upto six values: x, y, z, x-rotation angle, y-rotation angle, z-rotation angle."
Karsten posted some explanations, related to his splitPts node and his PointExt node.
7777.675
9189.16
9189.20 "at first - yes it's a frame description:
x,y,z, Euler-angles (x,y,z by using rotation order x,y,z), scale mostly 1 (useful for some programming - can be used as scale factor or for transformation proposes (homogenous coordinates)."
7777.1336
Puzzled - Brian
The pSize (scale) input is Karsten's PointExt node does not seem to work either?
13 Sep 2019   [#164] In reply to [#163]
So wait and see more info! :)
13 Sep 2019   [#165]
Point Node (English french)
14 Sep 2019   [#166] In reply to [#163]
Brian & Pilou,
>> It does seem like ScalePts node is not working. <<
ScalePt node works but only in combination with clonetoPts node.
>> For each point can be set upto six values. <<
Actually 7 values, including scale as shown on splitPts node output.
Have a great weekend
