Show messages:  1-11  …  72-91  92-111  112-131  132-151  152-171  172-191  192-211  …  492-503
9 Sep 2019   [#132] In reply to [#131]
<< script: if ( moi.majorVersionNumber == 3 ) { moi.ui.alert('running in v3'); } else if ( moi.majorVersionNumber == 4 ) { moi.ui.alert('running in v4'); }
it's just an Alert or that makes also good running of the good Shortcut ?
And where put it ? At the begin line of the script of the Shortcut Elephant ? or ...
9 Sep 2019   [#133] In reply to [#132]
Hi Pilou, you would need to replace the alert with the code that opens the node editor dialog.
So for example if you want to have v3 do this:
​moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
and have v4 do this:
​moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
You would place the v3 code in this spot:
and place the v4 code in this spot:
So the whole thing would look like this:
script: if ( moi.majorVersionNumber == 3 ) { moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); } else if ( moi.majorVersionNumber == 4 ) { moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); }
Hope that helps!
9 Sep 2019   [#134] In reply to [#133]
That was not evident indeed but miracle...
the "Whole thing" works inside the both V 3 (0.97) and beta V 4 (1.0) ! (in the same time :)
Bravo! No more headaches for this for me now!
(i will try again if the 1.0 works also for the V 3 )
9 Sep 2019   [#135]
Second miracle: the 1.0 works now also for the V3 !
Excellent! :)
Added to the Install http://moiscript.weebly.com/install-elephant.html
9 Sep 2019   [#136]
About of the Rotate Node
"Frame" parameters are yet nebulous :)
box = 5 , 5 , 2
Edit : ok I have found the missing link - a true moment of inspiration! :)
9 Sep 2019   [#137]
Maybe there is a trick for make a Rotation / a 3D Line ?
Rotate Node (English French)
http://moiscript.weebly.com/transform.html
10 Sep 2019   [#138]
Twist Node ( English French)
10 Sep 2019   [#139]
Flow Node (English French)
10 Sep 2019   [#140]
Circular Array Node (English French)
10 Sep 2019   [#141]
I have some troubles with Orient Node!
Seems no automatic "orientation"! ???
10 Sep 2019   [#142] In reply to [#141]
Hi Pilou, I think you'll need to supply a coordinate frame at your desired position instead of just a point.
10 Sep 2019   [#143] In reply to [#142]
Ok but i don't see difference from a simple "Move" + "Rotate Point" against "Orient" + "Rotate Point" ?
And I must find something who give the exact orientation because with sliders there is not "snap" :)
Something like a "given face" gives the orientation of it...or...
And other thing : does the "Native functions" can work only from them ? So making "Orient" just with them...
10 Sep 2019   [#144] In reply to [#143]
Well the regular Transform > Orient command is indeed a combination of movement plus rotation. With something that might have more complex rotations orient could be more convenient. Like if you are applying some kind of repeated rotation on a coordinate frame Orient can take that coordinate frame directly.
Sorry, I don't understand this part.
10 Sep 2019   [#145] In reply to [#144]
Actually there are 2 parts of nodes : native and extensions
So i will to know for example if native Orient can be used only with native nodes for obtain an exact results !
Because it was created before the extensions!
Problem for the moment i can't find a simple trick for have the good result!
Difficulties (for me) is transform a selection in a "frame" usable! :)
Orient something following a line or a face...surely trivial but...
10 Sep 2019   [#146] In reply to [#145]
Sorry, I don't know the answer to this.
For a curve you could call evaluateTangent on it to get its tangent direction and use that as the z axis of your frame, and you would then need to make the x and y axis directions by doing some vector math like using crossproduct.
If a curve is planar, (crv.isPlanar == true) then you can get the frame of its plane by crv.planarFrame
The next v4 beta will also has that for faces as well.
10 Sep 2019   [#147] In reply to [#146]
yes but seems all that is in the "extention" parts!
So stay in stand by till I finish the "native" part :)
10 Sep 2019   [#148]
Section POINTS
http://moiscript.weebly.com/points-e.html
Points Node (English French) not sure of what is this! (from where comes the first curve of points? A simple line of ... by default because I have nothing selected! :)
11 Sep 2019   [#149]
InterpPts Node (English French)
11 Sep 2019   [#150]
SpherePts Node ( English French)
11 Sep 2019   [#151]
PolygonPts Node ( English French )
