Full Version: Cutting model based on camera angle
Show messages: All  1-3  4-6
12 May 2019   [#4]
Oh, is it also possible to disable perspective in 3d mode? basically make it an ortho 3d view?
12 May 2019   [#5] In reply to [#4]
Hi Nebuka, yes there is a setting for disabling perspective in the 3D view under Options > View > 3D View projection. Set it to 3D view projection: Parallel.
That will modify the 3D viewport for the current file. If you also want it off by default when you first start MoI, save off a .3dm file with it set how you want and then put in that .3dm file as the startup template under Options > General > "Template file".
14 May 2019   [#6] In reply to [#5]
perfect, Thanks Michael
