Show messages: All
1-3
4-12
Thank you Death, but I already tried these settings, but it can't exactly reproduce the viewport settings.
Thank you Michael,
I could solve my problem reading the threads.
My solution now is to
1) Get the Position with a script using a hotkey:
script:var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); moi.copyTextToClipboard( 'Camera=' + v.cameraPt.toString() + '\r\nTarget=' + v.targetPt.toString() );
The result is:
Camera=407,04,-682,82,-230,78
Target=62,01,-44,72,-21,64
2) Replace some commas with points:-(((
Camera=407.04,-682.82,-230.78
Target=62.01,-44.72,-21.64
3) Edit the script for the camera:
script: camPt=moi.VectorMath.createPoint(407.04,-682.82,-230.78);targetPt=moi.VectorMath.createPoint(62.01,-44.72,-21.64);moi.ui.getActiveViewport().reset();moi.ui.getActiveViewport().setCameraAndTarget(camPt,targetPt);
4) Enter the script using TAB.
It works, but is not very comfortable.
Hi Samba, maybe try this method instead:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6962.13
Is that any better?
this makes it a lot easier. Thank you very much.
Hi Samba, you're welcome!
Also if you're going to that particular dialog frequently you can set up a shortcut key for showing it. Put this in as the command part for the shortcut key:
script: moi.ui.createDialog( 'moi://ui/ViewAngleDialog.htm' );
Thanks again for this hint!
This will speed it up a lot. I have so many different view in my documentation.
Is there any change to automate the process of converting the given coordinates into a reusable format without changing comma to dots and spaces?
Result of the 1st script:
Needed Values for the dialog box:
407.04 -682.82 -230.78
62.01 -44.72 -21.64
Samba
Hi Samba, do the different fields in the dialog not use commas for the decimal separator when you first open it? It is supposed to if your operating system language settings have that set.
Does this work where the numbers are separated by spaces? :
script: function str(pt) { return moi.ui.formatCoordinate(pt.x,2) + ' ' + moi.ui.formatCoordinate(pt.y,2) + ' ' + moi.ui.formatCoordinate(pt.z,2); } var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); moi.copyTextToClipboard( 'Camera=' + str(v.cameraPt) + '\r\nTarget=' + str(v.targetPt) );
Let me know if that still isn't quite right.
I always get the commas as the decimal separator. This is the return of the last script:
Camera=10,24 -20,48 10,24
Target=0 0 0
My system is set to German.
Samba
Hi Samba, and that doesn't work to put in those comma decimal separator values in the dialog?
Here's another version that should make period decimal separators:
script: function str(pt) { return moi.ui.formatCoordinate(pt.x,2).replace(',', '.') + ' ' + moi.ui.formatCoordinate(pt.y,2).replace(',', '.') + ' ' + moi.ui.formatCoordinate(pt.z,2).replace(',', '.'); } var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); moi.copyTextToClipboard( 'Camera=' + str(v.cameraPt) + '\r\nTarget=' + str(v.targetPt) );
it's a bit funny. The extended view angle dialog shows the camera and target position with commas on my system, but it only accepts the coordinates with a period decimal separator.
So, the last script solved the problem for me.
Thank you very much for spending so much time.
Samba
Show messages: All
1-3
4-12
