11-30
31-50
51-70
71-75
Moi is the Swiss knife! ;)
About GAEA - fresh air! a free version is existing! ;) (technology of the French SketchFab is some amazing!
(of course in Full screen on your biggest monitor = pleasure of the eyes!)
@PaQ
Best regards
Re-rendered this guy, to get rid of the chocolate look … :-D
beautiful
Thank you!
Picked some closed curves from an old MoI project and run it also
through PaQ's set-up, with a grid setting of 1024x1024, which then
shows the curves nicely.
the PaQ's set-Up is only for Houdini for be sure ?
Yes, only for Houdini.
you can try to do the same with ArtForm and the function "Region Relief",
once you have imported the curves and defined them as new model.
I will try that! :)
I have ArtForm Pro 3.5 (or named 4.0 at start screen)
Does it Updated for a new free version ? (yet sufficient...just for info... :)
(remember that was a little trick to install :)
And it's not an easy intuitive prog! :)
3.5 or 4.0 is imho the same, they renamed it only because of the Pro vers. which
was 3.0 IIRC.
About update, it checks for updates but you have to login and try to get the latest
version. I tried that but could not find it and the thread show me a little lock when
i want to download. Translated it says i must send a message to the admin/moderator
to get the file.
No problem, it was yet a fabulous prog!
Here is another idea from an old MoI file. Not sure if polygon meshes can be used for
vacu forming wall panels …
Peano curve like :)
:-) , it is a Sierpiński curve (arrow head).
O.k. before i go on and do other things, one more. Hope you like.
This is wonderful.
Congrats!
Thank you Marco!
11-30
31-50
51-70
71-75
