Full Version: Blender add-ons
Show messages:  1-9  …  30-49  50-69  70-89  90-95
12 Jul 2021   [#90] In reply to [#87]
Hi NaN,
> Ok, so the face dimensions are much larger, so it doesn't only affect the local area but the entire object?
Yes that's correct that the dimensions of a face's "underlying surface" can be much larger than its current active area. You'll get that when you do things like booleans. After the boolean is done the surfaces all stay the same and they get new trimming boundaries on them.
When you pull around surface control points in a situation like that then it's pretty easy for the modified surface to no longer intersect with the other ones that it was intersected with to produce the current trim boundary.
So usually in CAD programs you do not form things by moving around surface control points as you do in a poly modeling program.
You can do it in some areas but not just anywhere.
> (Different from the example in the faq, where unaffected points of the same object were editible?).
Well it's the same as in the FAQ - the FAQ shows how editing control points on a plane where there was an edge formed by the intersection between the plane and a cylinder will open up a gap.
12 Jul 2021   [#91] In reply to [#89]
Hi Nan,
> Being focussed, doing one thing really well is probably one of the biggest advantages of MoI :)
Well it keep things less complicated and that helps make it easier to use for the things that it is good at like quickly drawing stuff.
In the future i do want to add more functionality for editing things after construction though. In CAD it's a fairly complex area to handle well.
12 Jul 2021   [#92] In reply to [#91]
The second biggest advantage of MoI is probably your support! Thanks, much appreciated, less fog, more clear sight now! :)
13 Jul 2021   [#93] In reply to [#92]
Definitely! Michael should get a support award.
4 Dec 2021   [#94]
28 Jan 2022   [#95]
Free & Pro
