Full Version: Blender add-ons
Show messages:  1-8  9-28  29-48  49-68  69-88  89-95
9 Jan 2020   [#49] In reply to [#48]
Wonderful things!
23 Feb 2020   [#50]
next soon ;)
27 Feb 2020   [#51]
Started! :)
16 Mar 2020   [#52]
17 Mar 2020   [#53]
Not addon but Bevel exploration! ;)
30 Mar 2020   [#54]
31 Mar 2020   [#55] In reply to [#54]
Wonderful :)
Thanks!
10 Apr 2020   [#56]
free https://luxcorerender.org (video in French but they are Subtitle)
François Grassard is also a French Blender Guru ;)
7 May 2020   [#57]
SketchUp on steroïds! :)
7 May 2020   [#58] In reply to [#40]
That looks so great! It is very similar to what I am trying to achieve with the node editor random building generator that James has so kindly put together. There are some great examples here. I'm fascinated by the amount of traction Blender is starting to generate. It seems like it's becoming quite a serious contender for some of the bigger software companies, even with their software being "industry standard". I definitely need to learn a bit more Blender, but I just love the smooth simplicity of MoI. It's such a pleasure to work with.
12 May 2020   [#59] In reply to [#1]
I'm surprised no one mentioned these
Makes working with bezier curves a lot easier
Bezier Tools
https://blenderartists.org/t/flexi-bezier-tool/1168179
Use bezier tools to layout the curves and curves to mesh to create the surface
Curves to mesh
https://blendermarket.com/products/curves-to-mesh
Select a row of vertex and create a curve to reshape the mesh with fall off.
bezier-mesh-shaper
https://www.blendermarket.com/products/bezier-mesh-shaper
Edit polygons with only the left mouse button
PolyQuilt addon for Blender 2.8
https://blenderartists.org/t/polyquilt-addon-for-blender-2-8/1168918
13 May 2020   [#60] In reply to [#59]
I also forgot Step importer and a few others
This may be of interest if you are exporting from Moi to blender vis step files
https://blenderartists.org/t/step-import/1203804
Also Quad Remsher. It's not free but it's the same quad remesher as in Zbrush and is very useful.
https://blenderartists.org/t/quad-remesher-auto-retopologizer/1170913
Volume preserve smoothing. Smooths out the vertexes with affecting the outside shape of object.
https://blenderartists.org/t/volume-preserving-smoothing/1115522/37
14 May 2020   [#61]
KIT OPS UNIVERSITY (free Kitbashing lesson for Blender newbies)
https://www.blendernation.com/2020/05/12/kit-ops-university-free-courses/
30 May 2020   [#62]
16 Jun 2020   [#63]
Some cool is not it ? ;)
25 Jun 2020   [#64]
Blender in shortcuts! :)
https://www.giudansky.com/illustration/infographics/blender-map
ELse
31 Jul 2020   [#65]
31 Jul 2020   [#66] In reply to [#65]
35 euros pour un kitbash ... mouais
y'en a à moins de 10 euros avec 1000 pièces par pack ! l'ami Oleg Ushenok en a des cools y compris un gros gratuit sur Gumroad
si on peut faire la promo des trucs payants .. je crée un topic Plugins pour Max ( qui permettent au final de des trucs de ouf dans moi ;) )
ceux qui sont bon marché ... hein ! ;)
2 Nov 2020   [#67]
Always amazed how Chipp controls this beast! :)
3 Nov 2020   [#68]
Hi All,
This addon helps you to create model with controlled scale and alignment, on the grids surface.
https://gumroad.com/l/VthLyO
