Ok. Thanks for pointing out solid thing while booleaning.
I tried inline script by selecting object > TAB > var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );> Enter > and nothing happened
Had to assign shortcut (also in latest V4).
But now it highlighted edges and have no idea how to close them effectively?
It's weird shapes inside object that I have no idea how happened as I was only booleing solids as far as I know.
I think the move that created the joined surface, was the boolean subs very close to the front end of the "boat". I went ahead and redid them carefully and I got a solid. The weird connection at the cylindrical part at the front is because I tried to retain as much of your original model as possible (I copied your own surfaces there).
If you try to boolean subtract the two solids at the back now, I think you get the expected result.
Thanks nemeless,
Is there a way of you showing me how that can be made other than some painstaking 20minute method? :)
Or point me to some resource where such things are explained.
Downside of MOI is that there is no training dedicated to explaining step by step countless functions that MOI have.
It's amazing what can be modeled there but workflow is "weird" for beginner non-programmer and adjusting models afterwards is such process that sometimes I want to end my life.
Especially with such models as I pasted where curves and planes are not on 2D.
1)Read the actual manual of the program, command by command: http://moi3d.com/3.0/docs/moi_help.pdf
I know it seems tedious and we are all used to things being chewed for us, but it's by far the best way to understand the tool.
2) Chipp Walters vids on youtube were a great help for me.
3) (and probably most important) Keep modelling stuff in MoI and create your own shortcuts for the tools you use most. With time, you will start working around problems and develop strategies to approach shapes. You will start to expect what could be an issue and start to enjoy the process. By getting familiar with construction lines, the edit frame and snap modes you will get a very undisturbed and intuitive flow, almost like sketching.
Hi Mr. Yuri, the type of model you're working on with some internal structures not really visible from the outside is not very typical. Being not very typical means that it's not too likely that you will find a tutorial that would cover exactly what you are trying to do here.
Model structures like that I'd say are inherently more difficult to work with, so I'm not surprised that you get frustrated. It's not great to work on an unusual and fundamentally difficult type of model as a beginner. It's better to work on simpler models as a beginner and work on more difficult styles when you have more experience.
But it can accelerate your learning curve to work on more difficult cases though too, as long as it doesn't cause you to give up rather than gain experience of course.
I'm examining your model now to see if I can repair it, the repair job is going to be fairly complex. For a start I think I figured out there is a missing piece here which reduces the naked edge count from 20 to 18:
Hi Mr. Yuri, I have attached a repaired version of your object that is now a solid and should now behave as expected with the boolean difference you wanted to do.
I needed to build 3 planar surfaces and one extrusion, and then use Edit > Join to glue those into place to eliminate the holes that were surrounded by naked edges which you saw highlighted when using that script.
Hi nameless,
I read the manual (trying to comply with RTFM policies) but there is so much info I'm not able to memorize all and I actualy have it in pdf handy but when I get a problem and search, maybe I'm using wrong keywords.
Watched Chipp Walters vids and basically all I could find but rarely they try to solve exact problem I encounter. And as I'm not profi 3d artist and programmer I don't sometimes put 2+2 together like other folks here using MOI.
I do model but it's not my profession and when I model I rarely need very simple part. I was using Designspark mechanical for long time but as I need more complex parts I did research and found MOI. Now even when there is something I could do in 5 minutes in DSM I do it in MOI as I want to learn. Many cases I crash on moi bugs, downsides or my inability to realize thing like above case.
As DSM was more intuitive (for me) it's not that easy to use MOI with same ease.
I know it is more powerful but I have to change almost everything I'm used to in creating models.
I am an illustrator/2d guy myself, that's why I said I totally get it. :) Trust me that it get's a lot better with persistence. I would not try to memorize the manual per se, just make a pass of each tool testing it on a very simple dummy project.
Pilou, shortcuts are not only to save time, I think. I feel it's a way to protect concentration and flow when one is concepting on such an intuitive tool as MoI. I highly recommend setting up shortcuts after you get some basic understanding, so that you start developing muscle memory to the point that you think "chamfer" and the edge is chamfered before you realize it. :))
I've found that I have to be very careful with fillets and chamfers as if I want to edit object itself after 3D printing it (to make adjustments for the part needed) it's really painful if it has filleted edges.
This is biggest downside of moi comparing to DSM that edits of finished models are more time consuming.
Also the fillets and chamfers have different math or whatever that MOI cannot handle them as good as DSM.
Aside those two above MOI is better on all levels I think.
Bad news for me that those two things are ones I use most often.
I know you used chamfers just as an example, but it reminded me of this :/
Hi Mr. Yuri, well when you get stuck or confused about something in MoI, don't hesitate to post your question here on the forum. That's how you will learn and improve. For example with this discussion right here now you know what causes a boolean to have missing pieces of the cutting object.
Doing complex models just inherently takes a higher degree of skill and so it will take time for you to develop that. Keep at it and it will pay off.
For chamfers and fillets it sounds like a good solution for you would be to use DSM and MoI in combination with each other, doing the fillets and chamfers in DSM. I'm not sure if DSM has the import capabilities that you would need for that, it is a stripped down version of SpaceClaim. It would probably work better to use the full SpaceClaim software but it's pretty expensive. It could be a pretty significant boost to your productivity though.
I also have some ideas to improve MoI that will help more too later this year.
Planning your modeling strategy ahead of time given the MoI3D core set of commands is helpful. Before getting far in actual modeling it's helpful to learn the fundamental commands and then take some time to think about different ways you can use those commands to create the model. Generally speaking it's not a great idea to cobble together little pieces into a model, sooner or later the model falls apart. Rather, make use of alignment tools, keep lines and surfaces lightweight enough to accomplish your objectives and if your strategy begins to fail don't be afraid to rewind to a safe point and try another path.
