Full Version: V4 beta Feb-27-2019 available now
Show messages:  1-8  …  109-128  129-148  149-168  169-188  189-208  209-218
27 Jul 2019   [#169] In reply to [#167]
Hi Larry, so I was able to find a bug in MoI's 3DM importer that was messing up the mould.quadlobe.toy.3dm import, that's the first one that you posted from CAD Exchanger in Rhino v5 format.
I've fixed that up so the next v4 beta will be able to import that file ok, thanks for reporting it.
28 Jul 2019   [#170] In reply to [#169]
Hello Michael,
Thanks for the update! That's fantastic.
I've converted the problematic propeller model to Rhino 5 .3dm as well and testing I found it's likewise not importing correctly in 3.0.
Can you please test your latest v4 beta version with this one as well? I've attached it to this reply.
Thank you for your time and consideration.
Best regards,
Larry.
propeller.3dm
28 Jul 2019   [#171]
Works as solid for obj export in V4 ;)
28 Jul 2019   [#172] In reply to [#170]
Hi Larry, yup good news the same bug fix solves that one as well. Here's what it will look like in the next v4 beta with the bug fix:
Thanks for reporting it! I'm still going to investigate the step import some more but it is usually quite a bit easier for me to figure out what's going on with .3dm imports.
28 Jul 2019   [#173] In reply to [#171]
Nope, it's not working in the current v4 beta, it just looks ok from that angle because the messed up part is on the bottom.
But it will work fine in the next v4 beta though.
28 Jul 2019   [#174] In reply to [#173]
This ?
28 Jul 2019   [#175] In reply to [#172]
Hello Michael,
Thanks a lot for confirming! Can't wait for the release v4 release!
About that, will the release 4.0 version need to be installed over 3.0, in the same folder? As an add-on or expansion of sorts? Or will it be a separate installation?
If it comes as a separate installer which can be installed in a separate folder, if I install it over V3 would it retain the plugins I installed? I'm sorry if these questions were already asked and answered earlier in this thread.
Thanks for your time and consideration.
Best regards!
Larry.
28 Jul 2019   [#176] In reply to [#174]
Hey Pilou,
That's indeed where the import issue in 3.0 is and it looks similar to your screenshot from the current beta of 4.0 so it was probably the same issue as in 3.0.
Best regards,
Larry.
28 Jul 2019   [#177] In reply to [#174]
Hi Pilou, yes that's the problem area, it will be ok in the next v4 beta though.
28 Jul 2019   [#178] In reply to [#175]
Hi Larry also I should mention that I'm hoping that the next v4 beta will be the last one and after that I'll switch to a very conservative mode trying not to make any more changes if possible to avoid introducing new bugs for the final v4 release. So if you have any other .3dm files that don't come across well now would be the time to send them to have a chance at getting them fixed for v4.
So far it seems that CAD exchanger .3dm transfer is working well other than this one particular bug though.
It's meant to be a separate installation, it's best not to try and install it directly in the same folder as v3.
I'm not quite sure what would happen. It's best not to try and intermingle a v3 and a v4 installation directly over top of each other in a single install folder. It's intended that v3 and v4 should be in separate folders. Probably what would happen is you would have a v4 that worked and the current v3 installation would be broken. Many of the binaries for v3 and v4 have the same file name like MoI.exe, etc... so if you tried to put them in the same folder the v3 ones would get overwritten.
For plugins, most plugins are installed by copying them into the commands folder, you would just copy those from v3's commands folder into v4's commands folder. Also v4 now supports an additional commands folder located in appdata, outside of the main installation folder. It's good to put plugins there instead because then future versions will find them them there instead of needing to copy them around.
28 Jul 2019   [#179] In reply to [#178]
Hey Michael!
It doesn't look like I have any more models which don't import correctly either as .step files or as .3dm files, after conversion with CAD Exchanger. From what I can tell, it looks like I'll be able to reliably use this pipeline going forward.
Thank you!
Best regards,
Larry.
28 Jul 2019   [#180] In reply to [#179]
Thanks Larry, that's great!
29 Jul 2019   [#181] In reply to [#180]
Hey Michael!
Me again, just came across another .step model that doesn't import correctly as Rhino 5 .3dm in MOI 3.0. What's unusual is that the .step file appears to import correctly.
I'm fairly sure this is fixed in the latest beta of 4.0 but just thought I'd report it anyway.
Thank you!
conical.throttle.valve.variant.B.7z
29 Jul 2019   [#182] In reply to [#181]
Hi Larry, thanks for sending it. Yes that is indeed another case of the same bug and it will come in ok now in the next v4 beta.
29 Jul 2019   [#183]
Will the next Beta contain the dimension tools?
29 Jul 2019   [#184] In reply to [#183]
Hi Rudl,
Yes!
30 Jul 2019   [#185]
Hi to all a think this was asked before but with upcoming version a figure out if planed a script or a new command to develop surfaces inside moi like Rhino here https://wiki.mcneel.com/labs/devsrf
thanks..
30 Jul 2019   [#186] In reply to [#185]
It seems a lot like LineWeb.
Maybe some of the new crv methods of MoI4beta could be adapted...(?)...coplanar tangents...
30 Jul 2019   [#187] In reply to [#185]
Hi pafurijaz,
Sorry no there are not currently any plans for developable surface focused tools in MoI. I would recommend using Rhino for those particular tools.
31 Jul 2019   [#188] In reply to [#187]
Hey Michael!
Hope it's not too late for the next beta but I've found another model of mine which MOI 3.0 seems to have trouble with and it's different enough from the previous ones that I think it might possibly be a different bug than the one already addressed. So I thought I'd upload it here so you can maybe test the latest 4.0 beta with it as well.
I provided the problem model in .sat, .step and .3dm (Rhino 5) format in the attached archive file. Can you please test this .3dm as well? I promise I'll stop bugging you afterwards :)
Thank you!
Best regards,
Larry!
threelobed.and.pentalobe.circles.joined.01.7z
