Full Version: exporting 2d
Show messages:  1-4  5-24  25-44  45-50
14 Sep 2007   [#25] In reply to [#24]
Hi Paul, I usually use PaintShop Pro for doing that. There are other image utility programs you can also use, some of them free like IrfanView.
But it is also possible to do it just with stuff built in to Windows - you can push the "Print Screen" button on your keyboard to put a snapshot of the screen into the Window clipboard, and then run the old Windows paint program (pbrush.exe), and inside there do a Ctrl+V to paste the image in from the clipboard, and then save as a JPEG type image out of there.
14 Sep 2007   [#26] In reply to [#25]
Michael ,
I just discovered the print screen method a few minutes ago.
I'm more of technician then a graphic artist so I even have to learn the basic stuff .
Here's a jpeg of a basic bassguitar body I'll try to cncrout it in a scaled size version next week .
Paul
14 Sep 2007   [#27]
a very complet graphic tool (and free) is Artwaever http://www.artweaver.de/ (multi languages)
It's like Toshop + Painter :)
14 Sep 2007   [#28] In reply to [#27]
Thanks for the link Pilou I'll check it out .
Paul
14 Sep 2007   [#29] In reply to [#28]
Your guitar remember my little tut :)
http://www.divshare.com/download/286136-d3d
Wait 5 second, Load it, Unzip, and open the html file in your favorite navigator :)
14 Sep 2007   [#30] In reply to [#29]
Hello Pilou ,
Thank you for the tutorial of the picture insert in Moi . I sometimes worked like this in 2d cad .
When you know certain measurements of the instrument or object in real you can scale the drawing to that and draw a real life instrument based on a picture .
It goes much faster in Moi than in my other cad programs .
Greets ,
Paul
15 Sep 2007   [#31] In reply to [#21]
@Pilou thread, 918.21
do you look for that?
Moi 3Dcurve, skined in Skechup
3d curve in Moi
Imported as dxf
skined
bubbled
smoothed
15 Sep 2007   [#32] In reply to [#31]
Seems you find the trick :)
You rocks! Indeed that is the task ! :)
You are a genius! :)
But how do you make that ?
With the sandbox or with an another plugin?
You use the 3ds format?
I am curious of that :)
What is your process?
first:
curves lines arrive in Sketchup as a Component and when you explode the component curves will become separated
second : what function use for the Skin, Buble etc...
15 Sep 2007   [#33] In reply to [#32]
Hi Pilou
NOOOOO no genius, (toolman, HIHI) is a plugin from:
http://www.tensile-structures.de/index.html
Tool is time-limited, =mesh triangles are produced internally ("Sketchup > tab View > show hidden"),
only closed line-loop is accepted, work slowly with complex 3D-curve.
It gives still few useful tools for combination Moi+Sketchup.
My faforits gives afterwards.
15 Sep 2007   [#34] In reply to [#33]
Ok I know this plug ;)
So you just select the curves by a rectangular selection?
15 Sep 2007   [#35] In reply to [#34]
Eap, or additionally +STRG,
or with Ruby InvertSelection.rb , selector.rb and other
15 Sep 2007   [#36] In reply to [#35]
Is that plug works fine with google Sketchup 6? (not the 6 pro)
Edit :Yes all works fine in Google Sketchup 6! :)
Thx for the remember of this tool!
So crazzy forms can be insert in Sketchup from Moi with the Converter of Mikael ! :)
15 Sep 2007   [#37] In reply to [#36]
Yes, since SK6FREE support with Ruby scripts.
***SK6FREE is only for non-commercial free.
Tutorials here:
http://www.3epraha.cz/
"> CAD/CAM systémy > Sketchup (further down) > Výuková videa (Left down)"
15 Sep 2007   [#38] In reply to [#37]
Yes G.SKetchup is a crazzy prog! :)
Ps Seems the english version of your site is not working !
15 Sep 2007   [#39] In reply to [#38]
Oh,
possible, but all video tutorials are in english-language.
16 Sep 2007   [#40] In reply to [#38]
@Pilou
Attempt: Moi + colored in Sketchup
+ after exported to Edrawings (3D interaktiv for Sketchup)
http://www.edrawingsviewer.com
Example: MoiSkEdw.zip (for view this file, IE recommended)
MoiSkEdw.zip
16 Sep 2007   [#41] In reply to [#40]
@eddi
Seems cool but we can directly export in 3Ds format from Moi for texture or colorize in free Google Sketchup :)
Google Sketchup can import 3Ds Format !
18 Oct 2007   [#42] In reply to [#8]
Wow. Just downloaded MoI3D and it is beyond excellent. And thanks to those on this thread for the DXF converter.
I also use SheetCAM and seem to be always looking for a usable CAD package to draw simple 2D parts for machining and 3D for a bit of concept modelling. I'm not a full time mech designer so can't deal with the neverending learning curves of various 3D packages (Solidworks, Alibre) or slow "Autocad style" of nearly every 2D package out there, which always seem to cost too much for casual use.
18 Oct 2007   [#43] In reply to [#42]
Hi adx, I'm glad that you like MoI!
If you end up cutting any designs you drew, please post a photo here, it would be fun to see them.
19 Oct 2007   [#44] In reply to [#43]
Will do. Though I since noticed that most circular or elliptical arcs end up "wonky" in DXFs, and even export as .ai and into Xara ends up a bit wonky. For machining, it would be nice if they could be converted into arcs and straight lines where possible, but it's early days, and more of a 3D app. Very cool.
