16-35
36-50
Michael ,
You're right I converted a file with surfaces and some curves . that's why I tought I was missing some lines and curves because they were actually surfaces, and the lines that were still there were the start lines and curves I made before making surfaces with them .sorry about that !!
I'll try some thing in the next days .
Paul
This script macro might be useful for some data transfer stuff - this will duplicate every edge of every surface or solid in the scene as a regular independent curve object. Those curve objects can then be processed into DXF using that utility.
You can do this manually by selecting all the edges and doing copy/paste, this just makes it easier to process everything with one keystroke if you've got multiple objects.
script:var breps = moi.geometryDatabase.getObjects().getBReps(); for ( var iBrep = 0; iBrep < breps.length; ++iBrep ) { var brep = breps.item(iBrep); var edges = brep.getEdges(); for ( var iEdge = 0; iEdge < edges.length; ++iEdge ) { var newedge = edges.item(iEdge).clone(); moi.geometryDatabase.addObject( newedge ); } }
To use it, go to Options / Shortcut keys and set up a new one, paste this in as the Command part.
That's works again here from a cube solid :)
each cubes' Edges are divided in small edges
But when you select all a face you can create a real face 3D:) (in google Skechup)
(cubes' edges are always divided)
Hello ,
I just tried the macro script and it all works well . Now I can see all the edge curves of the surfaces when I use the convertor to DXF.
Many thanks ,
Paul
In fact i have found a plugin for Sketchup who repair the "lines broken colinear" so that solve my problem for the straight lines on the 3dSpace :)
If someone is interested that is that
http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/repair_broken_lines.rb
For a 3D curve no linear seems that is more difficult to use it for build a surface :)
But maybe exist a new ruby script who knows? :)
It is strange that it breaks the lines in the first place... I wonder why they decide to do that?
They may process Line entities instead of Spline entities better. There are a lot of different ways to store stuff in a DXF file, right now that converter just exports everything as a Spline object, but for version 2 I want to add an option to output stuff like line, circle, and arc entities instead of everything as a spline. That might help for some situations.
In fact a simple line from Moi in 3dm converted in DXF is imported in Sketchup as a "Component"
So when you explode it you have these divided lines ! (Mysterious I am agree :)
Michael ,
You can also sign me up for version 2 .
By the way How do I turn screenshots of moi into a Jpeg so I can put them on the forum for documentation ?
Paul
Hi Paul, I usually use PaintShop Pro for doing that. There are other image utility programs you can also use, some of them free like IrfanView.
But it is also possible to do it just with stuff built in to Windows - you can push the "Print Screen" button on your keyboard to put a snapshot of the screen into the Window clipboard, and then run the old Windows paint program (pbrush.exe), and inside there do a Ctrl+V to paste the image in from the clipboard, and then save as a JPEG type image out of there.
Michael ,
I just discovered the print screen method a few minutes ago.
I'm more of technician then a graphic artist so I even have to learn the basic stuff .
Here's a jpeg of a basic bassguitar body I'll try to cncrout it in a scaled size version next week .
Paul
a very complet graphic tool (and free) is Artwaever
http://www.artweaver.de/ (multi languages)
It's like Toshop + Painter :)
Thanks for the link Pilou I'll check it out .
Paul
Your guitar remember my little tut :)
http://www.divshare.com/download/286136-d3d
Wait 5 second, Load it, Unzip, and open the html file in your favorite navigator :)
Hello Pilou ,
Thank you for the tutorial of the picture insert in Moi . I sometimes worked like this in 2d cad .
When you know certain measurements of the instrument or object in real you can scale the drawing to that and draw a real life instrument based on a picture .
It goes much faster in Moi than in my other cad programs .
Greets ,
Paul
@Pilou thread, 918.21
do you look for that?
Moi 3Dcurve, skined in Skechup
3d curve in Moi
Imported as dxf
skined
bubbled
smoothed
Seems you find the trick :)
You rocks! Indeed that is the task ! :)
You are a genius! :)
But how do you make that ?
With the sandbox or with an another plugin?
You use the 3ds format?
I am curious of that :)
What is your process?
first:
curves lines arrive in Sketchup as a Component and when you explode the component curves will become separated
second : what function use for the Skin, Buble etc...
Hi Pilou
NOOOOO no genius, (toolman, HIHI) is a plugin from:
http://www.tensile-structures.de/index.html
Tool is time-limited, =mesh triangles are produced internally ("Sketchup > tab View > show hidden"),
only closed line-loop is accepted, work slowly with complex 3D-curve.
It gives still few useful tools for combination Moi+Sketchup.
My faforits gives afterwards.
Ok I know this plug ;)
So you just select the curves by a rectangular selection?
Eap, or additionally +STRG,
or with Ruby InvertSelection.rb , selector.rb and other
16-35
36-50
