Show messages: All
1-11
12-14
Hello Michael,
A further tweak…maybe? The 3DX driver must be ON before MoI4 is ON.
Otherwise the Spacemouse does not work.
With V3 the 3DX driver can be turned on after MoI is running and the controls work.
Ivan
Hi Ivan, that is intentional behavior, it is recommend by 3DConnexion to avoid a potentially long initialization when no 3DX driver is present at all as described here:
https://www.3dconnexion.com/forum/viewtopic.php?t=2814
If you are going to be using the Spacemouse, can't you have it set to run at machine startup and always have it running?
thank you
Show messages: All
1-11
12-14
