Full Version: V4 beta Oct-17-2018 available now - SubD to NURBS conversion
Show messages:  1-16  …  197-216  217-236  237-256  257-264
25 Feb 2019   [#257] In reply to [#256]
Hi Lordfox,
> Is it possible, to import an OBJ too but without SUB-D?!
Sorry, no not with any built in tools. An OBJ file without Sub-D is a faceted polygon mesh model and MoI is not designed to work with that kind of data for modeling. You would need to use a polygon mesh modeling program to import and work with that type of data, not MoI.
> Any possibility to set the strength of the build-in-SUBD?
Sorry, no not currently, it just uses the standard Catmull-Clark approach. At some point in the future I do want to add some edge weighting options but that would be unusual to do that directly in the OBJ importer.
> And for some OBJ Objects I dont want have SUBD ... e.g. if I import a pose from DesignDoll - nice tool
> for posing, but the poly-mesh-structure is very weird, lot of tris and so on - SUBD will not work well or
> much too long.
That model data is just not suitable for use in MoI in general - it's not what MoI is focused on working with.
26 Feb 2019   [#258] In reply to [#257]
Hi, thanx ... but it runs good - the new SubD fuction - I have made some bevels in a polygon-modeling tool. Thank you so much. But one Polygon-Object I cant load with the SubD Tool. I dont know why, its very simple, no holes, only quads (754 Vertices) ... hmmm I dont know .... created in Silo 2.5.5.
http://www.mediafire.com/file/h04eys1g8e9mtc4/Rohr.obj/file => Rohr.OBJ thats the Missing Part
This OBJ I can also create in moi very easy and fast ... but please tell my, why I cant load.
Looks very well
https://i.imgur.com/gf9b82j.jpg
The guy I dont want import by SubD, but I can't import the thing between the seat and the ground. Im confused. Maybe a bug in the Beta Release? Or an issue with Silo?!
26 Feb 2019   [#259] In reply to [#258]
Ok That works with Wings 3D! ;)
(ps when you have such single object put it at the origine and not at the out of space! ;)
But your file has curious colors in some other free prog MeshLab, MeshMixer...
Here the OBJ...http://moiscript.weebly.com/uploads/3/9/3/8/3938813/rohr4.obj
And for this simple object you have better time to redraw it in Moi! ;)
Because 2 Millions polys at Maximum export is maybe not a cool deal! :).
And seems your model has some defaults...
26 Feb 2019   [#260] In reply to [#258]
The two ends of the tubes have triangles, and T vertices.
By importObj script, and splitting the ends triangles, and saving, the tube will subD, but the ends are still polygons...
26 Feb 2019   [#261]
@Pilou
I dont understand, why you see 2 Million Polys? But thanx, I will try out other pivot-settings.
@bemfarmer
thank you too - so I will take look to this too
I'm happy now .. it was my fail - did overwork the tube-ends. Now ist fine ...
https://i.imgur.com/ByHQ19d.jpg
26 Feb 2019   [#262] In reply to [#261]
When you import it by SUbD inside Moi
then export it as obj you have a choice to 67 000 (mini) to 2 000 000 polys (maxi) ;)
26 Feb 2019   [#263] In reply to [#258]
Hi Lordfox,
It's because there are errors in the mesh structure, some degenerate faces and some faces with inconsistent normal directions.
The Rhino check command says:
quote:
This is a bad mesh.
Here is what is wrong with this mesh:
Mesh has 4 degenerate faces.
Important things to consider with this mesh:
Mesh has 128 faces with directions different from the mesh as a whole. Although this does not
necessarily mean that the mesh is bad, it can cause problems if you're doing mesh boolean operations with it.
Mesh has 4 pairs of faces that intersect each other. Although this does not
You may be able to fix it by using the "unify normals" tool in Silo:
https://nevercenter.com/silo3d/wiki/index.php?title=Unify_Normals
In the next v4 beta which should be released just later today, the sub-d conversion will skip over the problematic faces and give this result:
27 Feb 2019   [#264]
Thanx ;) - so its a problem of silo, wrong faced polygons in silo sometimes black and I see it and I fix it, but in somtimes my silo-object looks clean and the wrong polygon(s) are not "black" in silo.
I will set a wacom key, that makes all faces unify and after this a save.
